For sure, if it gets good enough, they will at least take part of the code, probably disabling the advanced settings.
Their developing is absolute crap, but, why even bother when it's already done and free?
They are like hienas, opportunists, makes me want to close-source it and request activations for a beer. F** them.
There's no really a big difference between these, else than higher speed and more memory.
Both are more than capable for the current fw, now more than ever, as it basically idles almost all the time, unless you board is crap and can't use hardware dma.
But why bother so much when you can buy few chips for little? The firmware itself is rubbish, specially the Quicko one.
Unless you do it for the challenge, which I totally understand, I've trashed countless hours on such things
If you want to power glitch it remember to remove or reduce the board capacitors, or they will filter the glitch out!
Dreamcat, that isn't a schematic itself. Just 4 resistors! haha.
But I agree to use a more standard schematic software.
The circuit is pretty simple, instead using the handle switch to short the sense pin to ground, it does it through a resistor, making a voltage divider with a known voltage.
If you put a parallel resistor, you will have always a voltage divider, but with a parallel resistor to it when the switch closes.
Again, the voltages are known, so you can perfectly know what handle type is plugged in, and the switch status.
