Author Topic: Easywave of Siglent (SDG1025)  (Read 4844 times)
Offline MalamaTopic starter
« on: September 17, 2012, 01:11:15 pm »
Is somebody uses Siglent Easywave software. It should build waveforms for signal generator.
This software is available on CD Rom and delivered with my Siglent SDG1025.
The version is :  V100R001B01D01P09 (1.1.1.7) setup file dated May, 21 2012
No problem during SW installation on computer, but when launch it :
  - Message box : "visa32.dll missing"
      >  install of visa32.dll
  - new message box : "agvisa32.dll missing"
      >  install of agvisa32.dll (find on Agilent FTP)
  - new message box : "Procedue input point not find in agvisa32.dll (lookupMsg@@GPADJ@Z)"
I uninstalled this Easywave version and installed old version (1.0) V100R001B01D01P03R2,
Setup file dated Sept, 05 2011.
This one can be launch without problem, but it is not possible to save waveforms, neither to send waveform to the device via USB port :
  - Message box : "Please connect the device with USB first"
then USB driver is correctly installed and USB device connected first.
Do you have some idea ?
Thanks, JC
Offline Bored@Work
Re: Easywave of Siglent (SDG1025)
« Reply #1 on: September 17, 2012, 04:27:11 pm »
Sounds like you should install a VISA runtime, either from NI or Agilent.
« Reply #2 on: September 17, 2012, 10:07:25 pm »
Thank you !
I install Visa runtime (V5.2 recommanded) from NI.
Caution : Visa runtime must be install before EasyWave.
Now :
 - Easywave (V 1.7) can be launched.
 - I can send a waveform to the SDG1025 as far as the file name is WaveX.
Nevertheless, it is not possible to save file waveform elsewhere "My documents" folder.
When I try to other folder : "save file" window disappears. Bug ??? Very basic Sw ???
« Reply #3 on: September 18, 2012, 08:32:41 am »
Rectification !!
 > False : Only file name does not include symbols as dash ...
