Author Topic: $20 LCR ESR Transistor checker project  (Read 3740457 times)
pierreraymondrondelle, mentholflash and 13 Guests are viewing this topic.
Offline stj
« Reply #2525 on: September 02, 2016, 10:23:55 pm »
did you calibrate it?
Offline Rudolf_h
  • Country: at
« Reply #2526 on: September 02, 2016, 10:33:51 pm »
hi
Thanks for the software, problem view video
https://youtu.be/sUbec_VTAhI
I have two of these testers im using the firmware you have downloaded and it works fine what are the fuse settings your using? what programmer are you using for the re programming,
Flash and EEprom is ok, fuse not shure
« Last Edit: September 02, 2016, 10:43:30 pm by Rudolf_h »
Offline flywheelz
« Reply #2527 on: September 03, 2016, 12:41:32 am »
@Rudolf_h,
Does the tester start automatically when you plug in battery?
Offline Rudolf_h
  • Country: at
« Reply #2528 on: September 03, 2016, 12:44:04 am »
sry no ;.)
its work, but the hardwae must be bad
the led and the display is always on and the test buton and rotator not works
Offline hapless
« Reply #2529 on: September 03, 2016, 01:46:39 am »
Have you checked the button to make sure there is no short in it?
Offline stj
« Reply #2530 on: September 03, 2016, 02:05:51 am »
button is not shorted or he would start in the menu mode
it was a kit - probably a resistor is in the wrong place or something.
Offline hapless
« Reply #2531 on: September 03, 2016, 02:16:27 am »
He does start in menu mode. And ends with "Timeout!"
Edit: I agree though, it could be something other than the button, but I think it's a good place to start.
« Last Edit: September 03, 2016, 02:22:03 am by hapless »
The following users thanked this post: flywheelz
Offline flywheelz
« Reply #2532 on: September 03, 2016, 03:27:21 am »
Maybe Atmega pin 13 always grounded by switch on NPN transistor.
Disconnect battery then check pin 1 and 2 for short in pic attached.
« Last Edit: September 03, 2016, 03:29:51 am by flywheelz »
Offline vinceroger
« Reply #2533 on: September 03, 2016, 12:44:00 pm »
hi
in your fuse settings lockbits i did not put anything in this section just the first three like you have set already and in extended fuse i set mine to 0x04
Thre is a good picture and zoomable so you can check the resistor colours etc in this thread post 349
 http://www.badcaps.net/forum/showthread.php?t=50720&highlight=esr+tester&page=18
maybe worth double checking these are in the correct places too
u3 = tl431
q1 - 4673 (bc557c)
q2 - c945 (bc547)
q3 - c945 (bc547)
« Last Edit: September 03, 2016, 03:45:24 pm by vinceroger »
Offline Rudolf_h
  • Country: at
« Reply #2534 on: September 03, 2016, 06:53:09 pm »
@Rudolf_h,
yes its start auto and is in a loop
transistor have i new and the start button has no bridge .. sorry bad english
https://www.youtube.com/watch?v=2H5j5LHh0Jc&feature=youtu.be
Offline vinceroger
« Reply #2535 on: September 03, 2016, 07:10:19 pm »
@Rudolf_h,
your video is set to private so we cant view it
Offline Rudolf_h
  • Country: at
« Reply #2536 on: September 03, 2016, 07:47:25 pm »
@Rudolf_h,
https://youtu.be/2H5j5LHh0Jc
the extendet is 0x04 ... xxxxx100 ignore the 5 bits
Offline Rudolf_h
  • Country: at
« Reply #2537 on: September 03, 2016, 07:52:29 pm »
i have checkt resistor many times .. all ok and on the right place
no brocken or bridges copper
now i have test pin 27 ( PC4 ) is always 2,5V on the pin
« Last Edit: September 03, 2016, 07:58:35 pm by Rudolf_h »
Offline madires
« Reply #2538 on: September 03, 2016, 08:02:27 pm »
PC4 is the external 2.5V voltage reference.
Offline Rudolf_h
  • Country: at
« Reply #2539 on: September 03, 2016, 09:11:32 pm »
sry my misstake wrong pin
when i press the test button must go pin 13 ( u1-13 ) to gnd ? is 0,6V presst or no presst test button
Offline madires
« Reply #2540 on: September 03, 2016, 09:30:32 pm »
PD7 (pin 13) is pulled up by a 27k resistor, when the push button isn't pressed. When you press the push button, a transistor pulls down PD7 to gound.
Offline vinceroger
« Reply #2541 on: September 03, 2016, 09:35:28 pm »
can you upload a high resolution picture of your tester like in the link in the thread i posted earlier we maybe able to spot something your missing.
Offline flywheelz
« Reply #2542 on: September 03, 2016, 09:49:55 pm »
He is getting 0.6v at pin 13 at all times which is wrong.  As madires said it should be about 5v when the push button isn't pressed.  Perhaps that Q3 is wrong transistor S9014 but for that tester you need c945 with different pinout?
What part number of Q3?
Offline Rudolf_h
  • Country: at
« Reply #2543 on: September 03, 2016, 10:08:16 pm »
first c945 and now bc547B
ok... i see ;-)
original c945
           BC547
in the GM328R stuffing list  q2& q3 - c945 ( bc547) !!
not pin compatible
« Last Edit: September 03, 2016, 11:02:52 pm by Rudolf_h »
Offline Rudolf_h
  • Country: at
« Reply #2544 on: September 03, 2016, 10:17:34 pm »
thats the problem, the is 0,6v presst or no presst
Offline Rudolf_h
  • Country: at
« Reply #2545 on: September 03, 2016, 10:28:09 pm »
Offline Rudolf_h
  • Country: at
« Reply #2546 on: September 03, 2016, 11:19:26 pm »
Thanks to all ;.)  |O |O
its works now Perfekt ;-)
Transitor wrong i insert original and now  :D :D :D :D :D :D
Offline flywheelz
« Reply #2547 on: September 04, 2016, 01:19:21 am »
Good job Rudolf!  One more working tester for the team.  :-+  :popcorn:
Offline roli_bark
« Reply #2548 on: September 04, 2016, 06:12:06 am »
I want to upgrade my AtMega328p-PU (the DIP part) to the latest repository 'madires' FW, but the part is locked.
- Can the ISP be used to completely erase a locked device ? Or, that a parallel HV programmer must be used ?
- I have the TL866 parallel programmer. How do I load it with both the *.hex & *eep files ?
TIA
Offline flywheelz
« Reply #2549 on: September 04, 2016, 06:24:21 am »
TIA
Yes you can Erase and start fresh.
I don't have any experience with TL866 but others here do.  Here is such a post.  Also I remember something about opening files as "intel".
