Author Topic: $20 LCR ESR Transistor checker project  (Read 3618292 times)
Vague and 54 Guests are viewing this topic.
Offline madires
« Reply #7975 on: November 14, 2022, 08:38:37 pm »
If that model got two unused pins and if T0 is also available then it should be possible to add the extended frequency counter. The next challenge is to make it small enough to fit into the case.
Offline juvann
« Reply #7976 on: November 15, 2022, 05:47:57 am »
Looking at the schematics available online PB0 (T0) and other 3 pins are available
So I will buy and I will try the mod.
what will be the maximum frequency that can be detected?
Thank you madires for the help.
Offline madires
« Reply #7977 on: November 15, 2022, 11:09:06 am »
I don't know the max frequency supported by the hardware of the extended frequency counter but for the MCU the theoretical limit is:
   f_max = MCU clock * prescaler / 4
(prescaler is 16 or 32)
Offline indman
  • Country: by
« Reply #7978 on: November 15, 2022, 11:23:49 am »
madires,are there plans future to add the SamplingADC function in your to doo list? ;)
External additional modules are, of course, good and they expand the capabilities of the tester.But if it is possible to use internal reserves and processor capabilities for the same purpose, then why not?
This is аctual true for a small portable device.
« Last Edit: November 15, 2022, 11:31:05 am by indman »
Offline madires
« Reply #7979 on: November 15, 2022, 03:29:15 pm »
Back then when Karl-Heinz added PA3FWM's idea of the SamplingADC I had a look at it and my first thought was that it's an interesting concept. On the other side I'd prefer a proper LCR meter when measuring such tiny values. Weighing up pros and cons I decided to not implement the SamplingADC. But if someone likes to implement it for the m-firmware I wouldn't hesitate to add the code.
Offline indman
  • Country: by
« Reply #7980 on: November 15, 2022, 04:03:15 pm »
This is definitely a great motivation for those who want to thoroughly understand PA3FWM's code, but this task does not seem too easy to me. Maybe I'm wrong. :)
Offline coromonadalix
« Reply #7981 on: November 15, 2022, 05:23:30 pm »
I'm surprised to see the lack of mega 1280 - 1284  2560 series of arduino's  .... or diy  boards
With bigger display shield(s)  it could be evolved further without costing an arm
Offline indman
  • Country: by
The following users thanked this post: coromonadalix
Offline BroMarduk
« Reply #7983 on: November 21, 2022, 04:23:58 pm »
Not sure if this has been pointed out or not but there's a small bug in config.h
Line 2082 is where it starts:
This
/* variable Start_str */
#if defined (SW_OPTO_COUPLER) || defined (SW_DS18B20) || defined (SW_ONEWIRE_SCAN) || defined (HW_EVENT_COUNTER)
  #ifndef VAR_START_STR
    #define VAR_START_STR
  #endif
#endif
Should be:
#if defined (SW_OPTO_COUPLER) || defined (SW_DS18B20) || defined (SW_ONEWIRE_SCAN) || defined (HW_EVENT_COUNTER) || defined (SW_DHTXX)
  #endif
#endif
At least that is the only way I can enable DHTXX without one of the others also enabled.
The following users thanked this post: madires
Offline Yuriy_K
  • Country: ru
« Reply #7984 on: December 01, 2022, 11:44:40 am »
When setting up sampling_lc.c for the TTester on MEGA 2560, I noticed the dependence of low inductance readings on the connection to the inputs with direct and reverse switching. This dependence is also observed on other measuring instruments. See for yourself in the picture.
Offline Feliciano
  • Country: ve
« Reply #7985 on: December 04, 2022, 08:51:08 am »
I don't know if that is an issue specific to the MEGA2560, but on other ctesters, I've noticed when I measure several times the same inductor --whithout moving it-- the results differ a little.
I haven't looked into the measurement subroutine, but maybe the method tends to let some remanent core magnetization. You may want to dig into that.
« Last Edit: December 04, 2022, 09:04:24 am by Feliciano »
Offline madires
« Reply #7986 on: December 04, 2022, 11:52:33 am »
The Transistortester uses DC for measuring inductance (standard measurement method, SamplingADC is a different story) while a proper LCR meter applies an AC signal.
« Last Edit: December 04, 2022, 02:23:05 pm by madires »
Offline Yuriy_K
  • Country: ru
« Reply #7987 on: December 04, 2022, 01:16:56 pm »
No, the testimonies themselves are stable, all meaningful numbers. Indications have more value when connecting the lower output of inductance to the input "1" and less when connecting the upper output of inductance to the entrance "1". The method implemented in sampling_lc.c is very accurate. I only adjust it to the length of the internal compounds of the Mega 2560 in the range of 40 nH - 2 μH.
 Here is a fragment from ttester-1.13k en.pdf
"...Together with a parallel connected capacitor the inductor build a resonant circuit. With a
short current pulse this circuit begins to oscillate some times without further stimulation. With the
sampling method the frequency of this oscillation can be measured..."
« Last Edit: December 04, 2022, 01:21:04 pm by Yuriy_K »
Offline Feliciano
  • Country: ve
« Reply #7988 on: December 05, 2022, 09:04:01 pm »
Currently I have one WEI with K-fimware and one of the new T7 (not a 324) with Chinese firmware. IIRC, the SamplingADC is enabled for the first one, but I don't have both equipment in front of me to take some snapshots now.
When I measure some chokes or transformers, the first(s) measurement(s) gives me one value, and further measurements tend to give me different, but reasonable stable, values. That's why I think the measurement method perhaps uses more pulses in one direction than the other, therefore having some sort DC offset which in some cases is more noticeable than others. But you guys know the code better.
Offline Spongey
« Reply #7989 on: December 06, 2022, 12:53:51 am »
I finally took the plunge and got a random version from eBay. From the outside this looks identical to the LCR-TC1 version but inside it has the same PCB as LCR-T7(FNIRSI) AFAICS complete with a (presumably fake) chip marked as MEGA328P.
When you power it up in test mode it says FNIRSI-TC1, pauses at 38% but it does not report the firmware version at the end.
I was hoping to reflash it, never mind.
Offline Yuriy_K
  • Country: ru
« Reply #7990 on: December 06, 2022, 07:30:00 am »
I propose a new version of the addition of the TTester circuit for measuring quartz and ceramic resonators in the range of 100 kHz - 20 MHz. The Chinese version HCF4060BE with a supply voltage of 6V and the use of an internal divider, allows you to measure quartz up to 20 MHz. Malaysian variant up to 16 MHz. I did not manage to lower the frequency for sentries (32768 Hz).
P.S. I apologize for some texts in Cyrillic, while debugging...
The following users thanked this post: Feliciano
Offline madires
« Reply #7991 on: December 06, 2022, 11:24:28 am »
Firmware-wise it would be the extended frequency counter without the input selection. I could add it as a new counter variation.
The following users thanked this post: Hernexto
Offline jemp
« Reply #7992 on: December 06, 2022, 04:37:59 pm »
Hello
Got 2 LCR Testers today from AliXpress..  New LCR-T4 and LCR-T7 Color
Both have new firmware version 3.12K
Does anybody know where to find this firmware.. or is it a hoax..  mean Chinese Variants.. ?
tnx for info
JP
Offline madires
« Reply #7993 on: December 06, 2022, 05:15:19 pm »
That's a modified k-firmware with fancy graphics and less features.
Offline indman
  • Country: by
« Reply #7994 on: December 06, 2022, 05:23:12 pm »
I'm not 100% sure, but these new firmware are protected for reading and are also designed for clones with Chinese-made microcontrollers. This is mentioned in my clone comparison table.;)
Offline Yuriy_K
  • Country: ru
« Reply #7995 on: December 07, 2022, 08:12:35 am »
To use the 4060 as a driver pre-amplifier, the following circuit must be applied. A multi-turn variable resistor will allow you to accurately set the maximum conversion frequency.
Offline jemp
« Reply #7996 on: December 08, 2022, 05:19:18 pm »
Hello, like in  #7908 I have also a MK-328 , with PCB 1.0 Date 2014/07/14
I programmed it with 1.13k..
Seems to be 2-3 versions.. with light fonts, or thicker fonts..
So programming no problem at all..
I works OK, starts up etc.. will do calibrate etc..  BUT....
I wont shut off ! when no component in it.. it goes blank and restart always again, automatically
Any thoughts ?
Does anybody has the ORIGINAL Firmware 1.11 ?
Tnx Jemp
Offline madires
« Reply #7997 on: December 09, 2022, 11:56:42 am »
The k-firmwmare has a setting for power management called POWER_OFF (in the Makefile). What have you set for POWER_OFF? Or have you disabled it?
Offline jemp
« Reply #7998 on: December 09, 2022, 02:38:13 pm »
Hi Markus
I did not compile the soft myself for the moment
I just flashed firm 1.13k, like attachment in msg #7910-11 and following
No firmware whatsoever closes the Tester Down... it resets itself constantly..
Could be a hardware failure..?
But I measures OK and perfectly.. just wont power off , after certain time
Offline madires
« Reply #7999 on: December 09, 2022, 03:07:57 pm »
A common setting for POWER_OFF is 5, i.e. the tester will shut down after 5 consecutive "no part found" messages. You could also try to press the test button for a few seconds after the last result.
