what is the use of empty while loop in embedded programming?
e.g while(test expression);actually i can't understand one line from this code
Generating a delay of 1 ms in PIC18F4550 using Timer1
www.electronicwings.com*/
#include "osc_config.h" /* Configuration header file */
#include <pic18f4550.h> /* Contains PIC18F4550 specifications */
#define Pulse LATB /* Define Pulse as LATB to output on PORTB */
void Timer1_delay();
void main()
OSCCON=0x72; /* Configure oscillator frequency to 8MHz */
TRISB=0; /* Set as output port */
Pulse=0xff; /* Send high on PortB */
while(1)
Pulse=~Pulse; /* Toggle PortB at 500 Hz */
Timer1_delay(); /* Call delay which provide desired delay */
void Timer1_delay()
/* Enable 16-bit TMR1 register, No pre-scale, internal clock,timer OFF */
T1CON=0x80;
TMR1=0xf830; /* Load count for generating delay of 1ms */
T1CONbits.TMR1ON=1; /* Turn ON Timer1 */
while(PIR1bits.TMR1IF==0); /* Wait for Timer1 overflow interrupt flag */ TMR1ON=0; /* Turn OFF timer */
TMR1IF=0; /* Make Timer1 overflow flag to '0' */
please explain the line "For ex: this type of while loop (without body) is used in wait & signal simaphore. "
I guess ..
Timer1 starts count from 0xf830. When it reaches 0xffff and overflows it makes TMR1IF=1.At the time of counting (i.e from 0xf830 to 0xffff) the empty while loop Wait for Timer1 overflow interrupt flag. When the overflow interrupt flag is high, the empty while loop fails .And the code continue executing the next line i.e
Please correct me if i am wrong...
