Author Topic: DSOX2000 and 3000 series - licence , have anyone tried to hack that scope ?  (Read 1138676 times)
Offline TheSteve
  • Living the Dream
Re: DSOX2000 and 3000 series - licence , have anyone tried to hack that scope ?
« Reply #2875 on: November 03, 2021, 06:50:42 am »
USB high speed decode and trigger doesn't work on 3000T. See up thread starting at post 2786 on page 112. Turns out there was a marketing/technical miscommunication.
LS and FS works.
Edit: even if HS did work, you'd need a 1GHz+ bandwidth scope. It does work on the 4000A and 6000X but they have hardware to support HS that the 3000T doesn't.
Looks like only the 1 GHz and 1.5 GHz 4000 series have the extra FPGA (U2303) and a few other IC's. Good thing I never had the chance to try modding a 4000 series to 1 or 1.5 GHz. It would probably be unhappy without the extra parts.
VE7FM
Offline Howardlong
« Reply #2876 on: November 03, 2021, 05:55:49 pm »
LS and FS works.
Presumably that means that certain 4000A bandwidth upgrades are RTB?
Edit: I guess so.
« Last Edit: November 03, 2021, 06:00:49 pm by Howardlong »
Offline TheSteve
  • Living the Dream
« Reply #2877 on: November 03, 2021, 06:45:07 pm »
LS and FS works.
Edit: I guess so.
Yes, it should be the same as the 3000a/3000t series more or less.
-100/200 MHz
-350/500 MHz
-1 GHz
-1.5 GHz
If you look on the Keysight parts site you can just see the added chips in the tiny pics on the 1 and 1.5 GHz models.
Like the 3000t series I believe all 4000 series use the same base PCB. The 3000A used an updated PCB for the 1 GHz model.
A lower model 4000 should still be possible to upgrade to 1.5 GHz as a crazy DIY project but adding BGA into the mix lowers my "excitement" level. If I was to take on such a project I'd want to be extremely confident it was going to work when done.
VE7FM
Offline Venturi962
« Reply #2878 on: November 03, 2021, 08:15:38 pm »
EEVBlog Flickr has a good photo of 200MHZ 4000X Series board with U2303 (bottom left between heatsinks) unpopulated:
https://www.flickr.com/photos/eevblog/8181558404/in/album-72157631997535516/
Closeup: https://www.flickr.com/photos/eevblog/8181518941/in/album-72157631997535516/  U2300, U2402 also unpopulated.
Offline TheSteve
  • Living the Dream
« Reply #2879 on: November 03, 2021, 11:38:52 pm »
Yes, he did a great job with those pics. I used them to confirm the lower frequency models didn't have the parts populated. Added parts are likely trigger related if I had to guess.
VE7FM
Offline dr3hl3rt
« Reply #2880 on: November 07, 2021, 04:22:01 pm »
I am having a wierd issue...
I have a DSO-X 3024A which is now a MSO-X - and I got the official 16-channel cabelharness from keysight
but... D00 on the cable is routed to D01 on the scope - and none of the channels can bring anything to D00 on the scope.
I am very confused...
best regards,
Henrik
Offline sbvr4
« Reply #2881 on: November 07, 2021, 04:32:50 pm »
Last I checked the link to generate the unique password to telnet in was down. Is that still needed to gain access via telnet? I have a 3000T.
Offline Venturi962
« Reply #2882 on: November 07, 2021, 05:09:52 pm »
If on PhillyFlyers FW:
User: infiniivision
Pass: skywalker1977
Offline TheSteve
  • Living the Dream
« Reply #2883 on: November 07, 2021, 06:38:35 pm »
User: infiniivision
Pass: skywalker1977
Did he patch out the unique password requirement for the t series?
VE7FM
Offline Venturi962
« Reply #2884 on: November 07, 2021, 09:14:19 pm »
Works for me on 4000X, so I would guess it's the same for 3000T as they share codebase.
Offline TheSteve
  • Living the Dream
« Reply #2885 on: November 08, 2021, 01:13:42 am »
I guess someone will have to try it, I can't as I don't run patched firmware.
I do know that telnet is disabled during the boot process on the 3000t series so you need to login quickly(with a script ideally) and kill the infiniivision process to stay connected.
VE7FM
The following users thanked this post: sbvr4
Offline sajsoni
« Reply #2886 on: November 08, 2021, 11:21:53 am »
Hello everyone, I have an Agilent DSO-X-3024A that didn't want to boot, so I followed the instructions from page 84 and successfully brought the oscilloscope back to life via the UART interface. after that I played a bit in U-Boot and (don't ask how) typed the erase flash command |O. Now when you turn it on, only one light comes on and nothing happens. Even on UART lines there is nothing ....
Is this the end for DSOX or is there a flash option to reload the U-Boot?
Offline tv84
  • Country: pt
« Reply #2887 on: November 08, 2021, 12:11:13 pm »
If there is no uboot, there are no options via software.
You must reprogram the SPI memory with the bootloader. I'm not sure that you must take it out. Others may confirm that.
Offline sajsoni
« Reply #2888 on: November 08, 2021, 02:26:20 pm »
How to load SPI memory at all and with which files?
In 3000XSeries.cab there are bin files that are related to uboot ....
I see that SPEAr 600 is based on dual ARM926, is there a possibility to load a new uboot via JTAG interface or some other pins? I tried with debug pins from SPEAr 600 datasheet and some ARM programmers, but I don't have a connection ...
I don't know where to start ... :-//
Offline TheSteve
  • Living the Dream
« Reply #2889 on: November 08, 2021, 04:12:17 pm »
This sounds like a pretty good challenge - to use the jtag interface two resistors need to be moved to enable it. I am guessing you already did that but if not see the details here:
https://www.eevblog.com/forum/testgear/dsox2000-and-3000-series-licence-have-anyone-tried-to-hack-that-scope/msg274963/#msg274963
Assuming the firmware updates have all of the required information you will still need to figure out the memory map and where to locate things.
I guess see if you can get u-boot installed and working and go from there.
VE7FM
Offline Bud
« Reply #2890 on: November 08, 2021, 04:44:28 pm »
It was a simple task on my 1000x , the SPI memory is a SOIC-8 chip on the back of the BLT module. Not sure what chip is used on the 3000 model.
Edit: this is astounding that it is possible to erase Uboot from Uboot, lol.
« Last Edit: November 08, 2021, 04:48:43 pm by Bud »
Offline Bud
« Reply #2891 on: November 08, 2021, 04:54:39 pm »
It was posted in the 1000x hacking thread how to connect JTAG to SPEAR600. You can look at that for reference but some details like pull up/down resistors may differ. I've done that on my 1000x.
Offline sajsoni
« Reply #2892 on: November 08, 2021, 05:30:17 pm »
Thanks for the answers, I missed that post about removing the resistor. I will try to remove them to see if I can communicate with SPEAR 600.
I know it’s impossible to erase, but is there a first time for everything  :palm:
Offline Bud
« Reply #2893 on: November 08, 2021, 05:42:54 pm »
Did you see this post?
https://www.eevblog.com/forum/testgear/dsox2000-and-3000-series-licence-have-anyone-tried-to-hack-that-scope/msg1458452/#msg1458452
It appears it may be possible to reflash the NOR (SPI) via USB. The USB Flasher utility seems to be still available from ST web site.
A bit of a challenge maybe in specifying a proper address in the scope memory map. You could try sending the OP a personal message.
The following users thanked this post: tv84
Offline tv84
  • Country: pt
« Reply #2894 on: November 08, 2021, 07:07:50 pm »
That post is the easiest way to do it, definitely. BTW, what address are you referring to?
Offline Bud
« Reply #2895 on: November 09, 2021, 03:44:13 am »
I mean the start and stop addresses for XBoot, UBoot and PBoot in the NOR memory space. But it should be possible to figure them out from the firmware UBoot binary image. The below is from my records for the 1000x NOR:
end of SPI Flash F807FFFF NOR
PBoot F8050000 0x946F NOR
Uboot F8010000 0x2FDD4 NOR
XLOADER F8000000 0x153A NOR
start of SPI Flash F8000000 0x80000 NOR
The third column is the length of the data blobs.
I am pretty sure the leading "F8" should be removed if the USB Flasher utility is used.
Again , this is for the 1000x. I do not know the setup for the 3000 scope.
Offline sajsoni
« Reply #2896 on: November 09, 2021, 12:05:24 pm »
I connected the oscilloscope to the PC, download the USB Flasher utility from https://www.st.com/en/development-tools/stsw-spear008.html
and ActiveTCL 8.16.11. I tried to follow the instructions in the USB Flasher to establish a connection with the SPEAR 600, but it didn't work on Win10 and Win7, at least it didn't work for me.
Then I tried on an old computer with WinXp and successfully connected to the SPEAR 600 SoC, only I had to find an older version of AcitveTCL 8.15.14 (http://www.softoware.org/apps/get-activetcl-for-windows- 32-bit-for-windows.html).
Now it remains to try to load XBoot, UBoot and PBoot ...
Offline sajsoni
« Reply #2897 on: November 09, 2021, 12:10:32 pm »
Thanks! I'll try with the specified layout in memory, I guess I can't destroy flash memory anymore
« Last Edit: November 09, 2021, 12:20:37 pm by sajsoni »
Offline Bud
« Reply #2898 on: November 09, 2021, 01:38:32 pm »
But configuring 3 partitions separately (Xboot,Uboot,Pboot) would require 3 separate bin source files. If the 3000 SPI firmware comes as a single file than it would need to be split using  respective  offsets for each partition. I guess alternatively only one partition can be configured for the size of the firmware and the entire firmware bin file loaded at once.
Offline tv84
  • Country: pt
« Reply #2899 on: November 09, 2021, 02:01:57 pm »
There is extra info besides the 3 blocks that goes into that mem. Namely, the MAC, GUID and S/N.
But I don't see why can't be flashed in one time only. Seems easier than it sounds to create the macro block.
