Looks like I'd need the 6000, so I guess ... not happening
THANKS!
My Support Subscriptions menu shows this ,what does the N/A mean.
SpacedCowboy
I bit late to the party here but check out the new 3000G data sheet, page 24. The G can measure X and Y jitter distribution and also does a variety of measurements on it. Also has bin width and other controls and can show S.D. of the jitter.
"Real" jitter analysis needs proper clock recovery but (I suspect) you're on your own as far as setting up triggers, record length, etc. so that you are analyzing NN clocks out from the trigger point. I believe the 6000 has a means of deriving a "recovered clock" for its jitter analysis in software.
Actually, the 3000T and 4000A do some of this but it's internal and intended for USB analysis and reporting.
SpacedCowboy
Thanks, I appreciate the thought
In fact, I ordered the MSO-8000 from Saelig (with their 6% discount) last week instead. Saelig were expecting it in today and just charged my card this morning, so I guess it's on it's way towards me now - probably another few days till it gets here since I'm on the West coast.
The '8000' I'd looked at the price of (and dismissed as too expensive) was in fact my mistake - whatever I typed in must have been wrong, because the prices I was looking at were in the $25k+ range. There's not a lot of price difference between the Rigol MSO8k and the Siglent 6000A at that level, but Rigol have far cheaper add-on options. Since I'm stretching my budget already (my current scope is a DS1102D
) that's reasonably important. In any event, this will be quite the upgrade!
Nice looking, capable rig.
I've hated the Rigol UI on their low end scopes. This front panel looks a bit more like an Agilent/Keysight configuration. I'm invested in Tek/Keysight probes, etc. and the USA, otherwise I'd consider them in the future.
Coyote is 4000. InfiniiVision is common sw for 2k, 3k, 4k.
economy DSOX2000A
performance DSOX3000A
coyote DSOX4000A
wolfhound DSOX6000A
monarch DSOX3000T
marsupial DSOX1000A
And what are those missing?Edit: added the new info.
wolfhound 6000A
monarch 3000T
marsupial 1000A
wolfhound 6000A
6000A is KeySight infiniivision 6000X
Not Siglent 6000A
I am not normally clumsy, but I tried to hack my 3104T (with the old bundle) from 7.50 official to PhillyFlyers' hacked 7.50 and while the update seems to have happened fine, I see no difference, in particular:
* No .lnk file (tried a bunch of different ones) has changed the options. I also tried no .lnk file. This is using PhillyFlyers' latest instructions to keep the .lnk file on the USB drive (in post 3033).
* I can telnet to the scope after boot, but the infiniivision/skywalker1977 password doesn't seem to work.
I have read a lot of the thread including several recent successes with 7.50, so I am confused about what I could have missed. For people who have successfully updated to 7.50, do the standard telnet user/password work?
I think there is no standard PW anymore. You have to generate a PW that matches the S/N... but anyways... Telnet is no longer required since PhillyFlyer invented his new method.
What is your .lnk File (show an example)?
Thanks!
I know I tried at least these and saw no difference (less or more options enabled):
39#infiniivisionLauncher.exe --perf -l All
39#infiniivisionLauncher.exe --perf -l DIS
62#infiniivisionLauncher.exe --perf -l all -l SCPIPS -l D3000USBB
For the password, I saw the mention of new firmware requiring a per-SN password, but then this (somewhat recent) post seemed to claim that hacked firmware could still use the standard password:
https://www.eevblog.com/forum/testgear/dsox2000-and-3000-series-licence-have-anyone-tried-to-hack-that-scope/2920/
Try this
98#"\Program Files\infiniiVision\infiniivisionLauncher.exe" -l WAVEGEN -l D3000BDLB -l SCPIPS -l SECA
Be sure that your .lnk file is named properly and that you haven't ended up with .lnk.lnk thanks to windows. It should be in your usb root folder.
Has anyone tried the PhillyFlyers' hacked firmware on a 4000X scope?
Yes - works fine.
Thanks for the feedback
Do you have a correct text line for the .lnk File?
I also want to thank everyone for all the great information in this thread. I got my hands on a non-booting DSOX2012A recently and was able to fix it easily over the serial console.
I mostly followed
https://www.eevblog.com/forum/testgear/dsox2000-and-3000-series-licence-have-anyone-tried-to-hack-that-scope/msg2136181/#msg2136181, but I put this in the infiniivision.lnk
44#\usb\infiniiVision\infiniiVisionLauncher.exe
instead of
48#\Secure\infiniiVision\infiniivisionLauncher.exe
From what I gather, this is the correct way, because it actually launches the app from USB. This should increase the chance of booting successfully even if the boot image does not match the installed version. Or at least it worked fine for me with 2.35. I am not sure which version the scope had before, but clearly an older one because it updated the keypad firmware on boot.
Yes - works fine.
You can use this (doesn't include bandwidth upgrades):
81#"\Program Files\infiniiVision\infiniivisionLauncher.exe" -l D4000BDLA -l WAVEGEN
I tested the patched FW 2.65 on a 2000X
It worked perfectly with this .INK file content:
128#infiniivisionLauncher.exe -l MSO -l COMP -l AUTO -l EMBD -l WAVEGEN -l MASK -l MEMUP -l SGM -l BW20 -l EDK -l DVM -l RML -l PLUSA big Thanks to PhillyFlyers
Does anyone know, if the Bandwidth of a 200 MHz 4000X scope can be upgraded trough software?
If so, what is the code for the .INK file?
For 200Mhz 4000A scopes,you can not upgrade bandwidth with options.
You must modify the hardware.
