Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
IR receiver - 1.8V?
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: IR receiver - 1.8V? (Read 1179 times)
Tantalum
Regular Contributor
Country:
IR receiver - 1.8V?
on:
February 10, 2019, 10:46:21 am »
Hello
Is there a 1.7-1.8V IR receiver available somewhere???
I can't find any, everything seems to need at least 2.0V.
Thanks
Logged
Twoflower
Frequent Contributor
Country:
Re: IR receiver - 1.8V?
Reply #1 on:
February 10, 2019, 11:17:40 am »
If you have still the 3.3V available and only the level of the data line is the problem you simply need a level shifter for that to go from 3.3V down to 1.8V.
Logged
Tantalum
Regular Contributor
Country:
Reply #2 on:
February 10, 2019, 12:25:07 pm »
Well, no I only have 1.8 available and and there is not much room left for a step-up boost converter.
Logged
Zero999
Super Contributor
Country:
0999
Reply #3 on:
February 10, 2019, 03:15:40 pm »
This the only thing I could find, but it doesn't seem like it's what you need.
https://datasheets.maximintegrated.com/en/ds/MAXQ617.pdf
How many are you building?
If it's just the one off, then you'll probably find most ICs specified for 2V operation will work down to 1.8V, so long as the temperature isn't too low. Another thing you might want to consider is increasing the 1.8V rail to 1.9V or even 2V, which no doubt your 1.8V devices will tolerate.
http://www.vishay.com/docs/82834/tsop942.pdf
https://docs-emea.rs-online.com/webdocs/1301/0900766b813013b7.pdf
The only other way is to build your own, from op-amps but I doubt there's room for that.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
IR receiver - 1.8V?
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
