alm: IPA worked a treat. Just squired a bunch on there, and worked the switch, and it freed up pretty nicely. Guessing I'll pick up some Caig stuff in the future to lubricate, but for now, it works.
PedraDaGr8: LOL! maybe subconsciously we're thinking "it's an inverter, it should be wired backward". =) You're probably right... but hell if I'm not going to replace the inverter anyway. I do wonder if the heat is part of it, because I'll admit, to get that sucker out, I really had to heat the crap out of it. Really wish ICs were in sockets by default, especially since there's room.
So, with the zener, I'd assume you've checked the voltage on it (or at TE1/TE2 in N3 mode) and it doesn't read right? $10 isn't bad for that part... I would assume just solder it quickly, in the right direction, and you shouldn't have any issue... but I'm not an expert.
As for title... will do. I've thought about that. =)
