Author Topic: Oscilloscope for AC work ?  (Read 5588 times)
Offline plurn
Re: Oscilloscope for AC work ?
« Reply #25 on: May 04, 2019, 03:03:48 pm »
The battery scopes like the siglent 810 and hantek's don't see to get the best reviews and I have no use for their multi-meter side. A fluke 125b could be nice for at almost $4k, hard to justify for this.
If you are on a budget, the siglent SHS1000 series would probably be more appropriate than the siglent 810 (SHS810 - SHS800 series). They seem to be very similar operationally, though the SHS1000 series has isolated channels with "Oscilloscope isolation level: CAT II 1000 V and CAT III 600 V" (this rating seems to be when using suitable 10X probes). SHS1000 costs more than SHS800 series, but a lot cheaper than the fluke equivalent, or most dedicated power analysers.
From the images here https://www.siglentamerica.com/handheld-oscilloscopes/shs1000-series-isolated-handheld-digital-oscilloscopes/ it seems to have FFT but I don't see a THD calculation there. If you don't need accurate THD calculation perhaps you could roughly work it out relatively easily from the dB levels of the fundamental and biggest harmonic on the FFT display using an online calculator or a table:
http://www.sengpielaudio.com/calculator-thd.htm
For example, if the fundamental is at -10dB and the biggest(loudest) harmonic is -50dB, the difference is 40dB. Then "Distortion attenuation a" = -40dB. Put -40 into the calculator and that gives THD% of 1%
Or just print out the "Table: Distortions and the dB and percent and the decibel" on that page and do a quick conversion. Probably easy enough to memorise too.
Depending on your business needs that might be close enough? Doubt you need THD% to 3 decimal places or anything but that is for you to determine. Perhaps you just need >5% is bad, <5% is good?
I am not an electrical engineer or anything so no idea if that is an effective or correct way of determining THD%. It is quick and easy though.
One other option though I don't think it fits your requirements, the Keysight U1242C multimeter (not an oscilloscope) measures/calculates something it calls "Harmonic Ratio" based on measuring RMS AC, and average responding AC. Details here: http://literature.cdn.keysight.com/litweb/pdf/5989-7687EN.pdf
Not sure if the AC bandwidth of the U1242C is sufficient? Doubt it goes up to 5kHz.
« Last Edit: May 04, 2019, 06:04:44 pm by plurn »
Online joeqsmith
« Reply #26 on: May 04, 2019, 04:03:45 pm »
If you are on a budget, you may want to look at a used one.   I've used one of these and they are pretty nice.  The problem is that they are no longer supported by HIOKI.  You can still get batteries but if anything were to get damaged, they will no longer service them.
https://www.ebay.com/itm/HIOKI-3196-POWER-QUALITY-ANALYZER/183792935792?epid=1501714264&hash=item2acae9a370:g:JwgAAOSwCtJcx4Zp
Offline plurn
« Reply #27 on: May 04, 2019, 04:44:26 pm »
found this - UNI-T UT283A Single Phase Power Quality Analyzer Energy meter
relatively cheap. Seems to have THD%. Don't know if it is any good or safe.
edit:
Harmonic analysis:   Up to 51th
Does that mean eg 60Hz fundamental * 51 = 3060Hz ? So might not show the 5kHz+ that you need.
http://www.uni-trend.com/html/product/General_Meters/Power_Quality_Analyzer/UT283_Series/UT283A.html
« Last Edit: May 04, 2019, 05:46:48 pm by plurn »
Online joeqsmith
« Reply #28 on: May 04, 2019, 05:25:08 pm »
Normally if I am doing this sort of work, an typical oscilloscope I would use for electronics would be useless.  The first problem is I not only need the equipment to survive in the field, I need it to capture some potentially large events (transients).   I normally need both current and voltage.   Complex triggers are a must.    I also want long term recording of the events and the ability to post process them.
When I was first looking for one of these, HIOKI (and others) had brought in demo units.  I ran transient tests on their demo units (with the approval of the sales men).   Not the little toy generators I use to benchmark the handheld meters, but the real deal.
I like the new HIOKI units.  Cost is about $10K USD but well worth it if you need this sort of tool.   I've used them to solve some pretty odd problems.
Then again, if the goal is just to look at the AC line voltage at one of your home's outputs for the sake of looking at it, this would be a total waste.
Offline plurn
« Reply #29 on: May 04, 2019, 05:29:22 pm »
Thanks for all the replies.
I'm currently considering the AEMC 407 clamp meter, with their free bluetooth software it might get me close enough to what I'm trying to find, at least it has some THD functions. I'm not 100% sure it'll get to the higher frequencies that might be in there but for a bit over $500 could be worth a try.
AEMC 407 clamp meter does "Individual Harmonics (to 25th)", so I would think that means 60Hz x 25 = 1500Hz only? So probably won't show 5kHz.
https://www.aemc.com/userfiles/files/resources/datasheets/Clamp-On-Meter/2139-51.pdf
« Last Edit: May 04, 2019, 05:47:19 pm by plurn »
Online joeqsmith
« Reply #30 on: May 04, 2019, 05:37:46 pm »
If it were to just for a home outlet and a few small devices, a standard scope may be fine.  Here is mine making some decent power measurements.
https://youtu.be/04I7nHA_HxM
Offline malagas_on_fire
  • Country: pt
  • Kernel Panic
    • Malagas Lair
« Reply #31 on: May 04, 2019, 09:19:51 pm »
Another budget alternative is the uni-t 81b portable scope which is CATIII 600  but keep in mind it hasn't got isolation on the inputs jacks and some come with glass fuses :P
http://www.uni-trend.com/html/product/General_Meters/Digital_Multimeters/UT81_Series/UT81B.html
Offline Jwillis
« Reply #32 on: May 04, 2019, 10:22:01 pm »
There is no danger measuring high voltage PROVIDED your at the SAME POTENTIAL  as the line your measuring.This means you do not complete a circuit to ground or any of the other lines.This is why birds can sit on high voltage service lines .If you equipment is at the same potential as the line your measuring theirs no risk of damage.This is what isolation is for.Provided you don't exceed the maximum input voltage of the probe or the scope.
The best and  safest solution to measuring mains voltage is through a step down transformer and measure at  low voltage.Any anomalies in mains will show up on the low side.then just do the math.
Or better yet don't measure mains at all.Why? If you have to ask then you are not qualified to do so and need to get a service person that is qualified to do so.They have the training ,knowledge and equipment for the task.
I simply don't understand why people ,when they get their first scope .need to run to the first outlet they see and stick the probes in.It's an  AC sine wave .It's always going to be an AC sine wave no matter which country your in.
Offline David Hess
  • DavidH
« Reply #33 on: May 04, 2019, 10:37:06 pm »
Either use high voltage differential probes with the oscilloscope of your choice or an oscilloscope with galvanically isolated inputs which is commonly designed specifically for power line measurements anyway.  But do not combine these two options.
Offline DDunfield
« Reply #34 on: May 04, 2019, 11:34:47 pm »
I have one of these, it's "OK" - UNI-T has been around for a while, and their stuff seems somewhat decent, but not up to the standards of the likes of Fluke or other top players.
It's basically a DMM with graphical display ability - quite useful at times, but not what the OP is looking for. It has no math or real measurement capability. It doesn't have storage other than the trace on the screen, no zoom etc. In "scope" mode it functions like a fairly basic analog scope, except that the trace hangs around till the next trigger.
The DMM leads are isolated/shrouded like most other DMM's. It's rated CAT II/1000 and CAT III/600 .. not sure I'd trust it like the Fluke, but I have no trouble poking around 120v NA mains with it. It is well built and insulated and there is no exposed metal.  It has a BNC adapter which is insulated like the Fluke (but lower quality) not clear what if any ratings apply when the BNC adapter is used, unless you have a properly isolated probe it wouldn't apply anyway, I don't use the BNC around mains.
It does come with an optical USB interface, and it's easy to make a optical RS-232 serial interface. I reverse engineered the protocol (which I documented somewhere) and wrote code to interface to it. It does let you save/recall the displayed waveform, so it would be possible to do some post-analysis on it, but it's just the display.
There a review on it:
   https://www.eevblog.com/forum/reviews/review-uni-t-ut81b-scopemeter/
And a teardown of the UT-81C which is just a faster version of it:
   https://www.eevblog.com/forum/testgear/uni-t-ut81c-scopemeter-teardownreview/
Dave
Offline SNDTopic starter
« Reply #35 on: May 05, 2019, 12:05:50 am »
I'm not sure, Specs say it displays to 25th, but the android app for the 407 and 607 models has a picture showing higher harmonics on a graph so maybe it senses them but just can't display higher than 25th? It does say the hz setting goes to 20khz but I'm not 100% clear on if it'll show me data up to that in the app, can't seem to be able to open the app I downloaded without having the unit in hand.   I like that it appears capable to check THD on current and voltage.
Offline plurn
« Reply #36 on: May 05, 2019, 05:49:22 am »
It certainly does look like a useful device for THD and as a general multimeter/clampmeter. I like it too from what little I know about it and I would not mind owning one.
From the manual it says "The frequency of the fundamental is determined by digital filtering and FFT for the network frequencies of 50, 60, 400, and 800Hz".
800Hz * 25 = 20kHz. So maybe you need the fundamental to be 800Hz to see that bandwidth? Or maybe you can see it for everything including 60Hz fundamental? I don't know. You could ask their customer support.
Also from the manual it says:
"Frequency Analysis Band - 0 to 25 times the fundamental frequency, from among the network frequencies 50, 60, and 400Hz
- 0 to 12 times the fundamental frequency of an 800Hz network". So that might be a limit of up to 10kHz?
I think maybe the 5kHz you are talking about is not really "harmonic" distortion related to the fundamental frequency of 60Hz. So something that just analyses harmonic distortion might not take it into account and probably should not be expected to. It could be considered some other sort of distortion (there are different types), or noise, or a seperate fundamental frequency. You have not really said why you expect a 5kHz noise to be present and a significant contributor (unless I missed it).
So if it is just "harmonic" distortion you are interested in, something like this device sounds great and is relatively affordable. If you really need to measure/view other sorts of distortion and noise, it may or may not do it - not sure. Hope it works out for you.
« Reply #37 on: May 05, 2019, 08:55:12 am »
I expect most of the noise to be from big IGBT's that run at 5khz. Its in the audible range anyway. There probably is some other regular harmonics since its tied to other vfd's and 3ph motors.
Offline BravoV
  • +++ ATH1
« Reply #38 on: May 05, 2019, 09:11:27 am »
My 2 cents, think of your probing mistakes in the past at low voltage circuits, and count as you can memorize, how many ? 1 ? 10 ? or even more ?  :P
Now, when it comes to high lethal voltage, all you need is just "one" mistake, is enough to zap your expensive measuring equipment, your circuits or even worst ... your limb or your life.
Again, think about it, is it worth the saving ?
As many had pointed out, the easiest & possible the most bang for buck is using HV differential probe. As probing mains related devices will be very comfortable, an example scope that was probing the mains line that powered the scope it self.
Also many pointed out, battery powered scope is not always a suitable one for probing lethal voltage.
Here, a design illustration, how a "proper" battery powered handheld scope that was designed for probing mains. Watch carefully how they separate & isolate each functions in the scope.
Also a proper scope and its accesories have NO exposed metal, including the BNC and also the whole probe's body.
An example of Tektronix THS7xx handheld scope for mains probing, watch the BNC connectors at the scope, no exposed metal.
Also the suitable probe, watch again carefully, all covered by non conductive material and its not easy for  human body parts can touch the metal parts.
The bad news is, handheld scope that is qualified for probing mains line, even used, especially top brand ones, still very expensive, and most of the times still more expensive than a brand new "decent" HV diff. probe.
« Last Edit: May 05, 2019, 09:26:37 am by BravoV »
Offline DDunfield
« Reply #39 on: May 05, 2019, 01:04:31 pm »
An HV rated portable scope is as suited to probing high voltages as an HV rated differential probe. In most industrial cases the battery scope is the better solution.
In addition to being great at demonstrating probing mains sockets, a bench scope with an HV-diff  probe is ideal when looking at non-ground referenced HV signals on an appliance on your repair bench.
But things like distribution panels, VFDs, large main connected inverters etc. aren't usually conveniently on your bench when operating under a load. These things are also not (usually) in the realm of things a typical do-it-yourself'er works with, but if you have particularly exotic hobby needs, you might "make due" with a bench scope and HV diff. probe.
This setup doesn't work on a job site.
Below is a small collage of images (shamelessly snarfed from web) which shows places where you might see someone comfortably taking mains related scope measurements on a job site.
I suppose you *could* use bungee cords to hang your bench scope on the panel.  Or perhaps drag in a table and extra long leads, making do with the scope where you can't quite see it (also fun when you need to move between several pieces of equipment).  But... where would you plug it in?  Better bring some extension cords too!
I suppose you *could* juggle a 1054Z while standing in front of a panel/equipment wearing heavy protective gear... but IMO much more likely to make a mistake, and again where to plug in.
I suppose you *could* balance your bench scope on the motor ... Not as stable as the flat rubberized scopemeter, but hopefully it won't fall off... But what if it does. How badly will it be damaged?
Making measurements of this kind, you avoid extra cables (the bench/diff-probe adds 2),  you avoid things that need to be plugged in, you avoid things that are hard to hold, you avoid things that are breakable ... bench scope fails on all of these counts. The scopemeter designed for this purpose is the right tool for the job.
And yes, sometimes the right tool for the job is expensive. If you're doing it once (or very infrequently) you might make due like MacGyver. If it's part of your job, you get the right tool, it will pay for itself (otherwise you may encounter a different meaning of  "bang for the buck").
Dave
Offline BravoV
  • +++ ATH1
« Reply #40 on: May 05, 2019, 01:36:12 pm »
...<snip>... This setup doesn't work on a job site.
I suppose you *could* ... <snip> ...
Dave, nothing against your post there, infact I do own a Tektronix THS710A, apart from that clumsy DS1054Z bench scope + HV diff. probe.  :P
Its just my response to OP which I see he just started on this matter, and there is nothing wrong on a bit cautious at spending big bucks, especially at early stage in venturing in this HV probing domain.
Looking at current HV diff. probe's price, imho, is an ideal starting point, rather than have to jump directly buying an expensive "decent" handheld HV isolated scope.
Offline DDunfield
« Reply #41 on: May 05, 2019, 06:24:42 pm »
...x3
Fair enough, and I'm not saying it can't be done that way, or even that you would never do it that way "If you're doing it once (or very infrequently) you might make due like MacGyver."
But what I am trying to do is counter the arguments that battery-powered scopes should not be considered, and that benchtop devices are better. In most industrial/on-site situations the opposite is more true.
I don't know the details of the OP's setup, however the original post mentions, VFDs (plural), 125A feeds,  and 3-phase. This suggests to me that it is an industrial application and that they do not bring in someone properly equipped to monitor/maintain it. I could be wrong. Perhaps it is a lab environment (*1).   But I think it inadvisable to make general statements that benchtop scopes with HV-diff probes are better for mains/power work than the tools professionals in the field use every day.
(*1) some years ago I was developing control systems for wind turbines. Mostly smallish, IIRC the biggest was 50kw. We did have a lab with among other things captive turbine heads driven by honkin big motors on VFDs. These were primarily used for developing/testing the regulation sub-systems. The heads produce 600v 3-phase. In the lab, I did in fact use benchtop scopes and HV-diff probes. That was because the high-power systems were actually on (or at least beside) my bench. I never took (or saw taken) a benchtop scope to the test rigs, or on site visits - there we used battery powered scopemeters.
Dave
