I have a swimming pool with Savi Melody lights installed. They keep failing, and the supplier won't replace them anymore. So, this time I'm going to try to fix the light.
The electronics seem fine, although I will replace the caps - you can see heat discoloration on the housing next to where they are located. What has failed is the red LED chip. It will be tricky to replace, but the trickiest bit is determining the part!
I've not yet been able to test this on a bench, but I assume all the LEDs are the same as the green one (D5), with 16 LEDs. The chip measures 4.75mm x 3mm.
Thanks for taking a look. I hope I can save myself the $200 it costs to get a new unit.
Anthony
