Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
low voltage LED replacement
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: low voltage LED replacement (Read 694 times)
Trebby123
Newbie
Country:
on:
May 17, 2021, 08:12:37 pm »
Hi
We have a night light projector for my daughter which is fitted with LEDs. Unfortunately we are now on our 3rd projector as the LEDs don't last long at all. I'm wondering if it's possible to replace them but can't find/I'm not quite sure what I'm looking for. It is powered by a 5v USB DC charger. There are some photos of the LEDs in the links below. If the LEDs are replaceable I would plan to remove and then solder in new LEDs. Would be grateful for any thoughts as to whether this is possible and where I can find similar LEDs. Please let me know if any more information would be helpful, and thanks again for your help.
https://drive.google.com/file/d/1CFFKNGpa6pefwImMtFao6FZbQoziDIV1/view?usp=sharing
https://drive.google.com/file/d/1FOqPfzEmEPb47u9XC9pm7jFqdZJPkfU_/view?usp=sharing
https://drive.google.com/file/d/1Zx-7nN9jCXfKoQMGcX6RE7k6i-LeL17H/view?usp=sharing
https://drive.google.com/file/d/1unFEmqsCCNuU5KTj7aQKjlLT4wpqX2j1/view?usp=sharing
Logged
Kleinstein
Super Contributor
Country:
Re: low voltage LED replacement
Reply #1 on:
May 17, 2021, 08:34:42 pm »
The LEDs look a little odd. The main question would be the needed focussing / divergence of the light. Another variable is the brightness - this can vary quite a bit between LED types.
The LEDs nearly look like they are damaged machanical by abrasion.
Logged
Trebby123
Newbie
Country:
Reply #2 on:
May 17, 2021, 08:36:57 pm »
Thanks for your reply.
The brightness isn't a big concern to me, but divergence would be useful. Is there a specific type of LED bulb that I should be looking for that will work with this circuit?
Logged
Kleinstein
Super Contributor
Country:
Reply #3 on:
May 17, 2021, 08:51:57 pm »
The broken LEDs don't tell much about the required LEDs. It would need mire a photo of the whole product, so one could see the approximate optics used.
Logged
tunk
Super Contributor
Country:
Reply #4 on:
May 17, 2021, 09:01:21 pm »
Could look like straw hat LEDs:
https://www.eevblog.com/forum/beginners/led-fail-on-magnifying-glass/
If you don't mind a dimmer light, you could use e.g. a 25ohm resistor in series.
This should increase the LED life.
Logged
Trebby123
Newbie
Country:
Reply #5 on:
May 18, 2021, 11:03:04 am »
Thanks for your replies. The product is this one
https://www.amazon.co.uk/gp/product/B085LZH566/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
I'm not too worried about longevity of the LED if I have an easy source to replace them. Is there any way of telling if those straw hat LEDs will fit?
Thanks
Logged
Trebby123
Newbie
Country:
Reply #6 on:
May 18, 2021, 11:08:44 am »
Do you think this would work as a replacement?
https://www.switchelectronics.co.uk/white-5mm-water-clear-led-2000mcd-30
Logged
Kleinstein
Super Contributor
Country:
Reply #7 on:
May 18, 2021, 11:34:24 am »
The LEDs look kind of OK, though still a little small angle. One could work around this by mountig the LEDs at slightly different angles.
The indensity also does not look very high, but it can be worth a try.
Logged
Trebby123
Newbie
Country:
Reply #8 on:
May 18, 2021, 11:35:26 am »
Thanks again - I'll try this and let you know how I get on!
Logged
EntropyWizard
Contributor
Country:
Reply #9 on:
May 18, 2021, 04:33:06 pm »
I have seen something like this in the backlight strips of LCD TV's. These are a little bigger but have the clear bead lens:
https://www.ebay.com/itm/202720399879
. Notice they also have a "concave" lens option as well. I don't know if you can get these unmounted fron the metal core board, but that is probably for heat sinking, which may be why yours are going bad so fast. Maybe you can fit some of these in your device.
Last Edit: May 18, 2021, 04:37:55 pm by EntropyWizard
Logged
Trebby123
Newbie
Country:
Reply #10 on:
May 18, 2021, 08:00:28 pm »
Thanks for your thoughts on this. I'm not quite sure how I would fit this. I'm going to try the smaller LEDs to start with.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
