Author Topic: EEVblog #169 - Samson StudioDock 4i USB Monitor Speaker Review.  (Read 5539 times)
Offline firewalkerTopic starter
Dave, can you post the PID, VID of the device?  ;D ;D ;D
Eg:
Re: EEVblog #169 - Samson StudioDock 4i USB Monitor Speaker Review.
« Reply #1 on: May 05, 2011, 11:55:00 am »
Not sure why it matters:
USB\VID_17A0&PID_0201&REV_0100&MI_00
« Reply #2 on: May 05, 2011, 12:35:28 pm »
Thanks m8.
With those number I can find many infos for the usability of this device under GNU/Linux (I think this one does work with snd_usb_audio module).
Bus 001 Device 004: ID 17a0:0001
    Device Descriptor:
    bLength                18
    bDescriptorType         1
    bcdUSB               1.10
    bDeviceClass            0 (Defined at Interface level)
    bDeviceSubClass         0
    bDeviceProtocol         0
    bMaxPacketSize0         8
    idVendor           0x17a0
    idProduct          0x0001
    bcdDevice            0.01
    iManufacturer           1 Samson Technologies
    iProduct                2 Samson C01U
    iSerial                 0
    bNumConfigurations      1
    Configuration Descriptor:
      bLength                 9
      bDescriptorType         2
      wTotalLength          177
      bNumInterfaces          2
      bConfigurationValue     1
      iConfiguration          0
      bmAttributes         0x80
        (Bus Powered)
      MaxPower               90mA
      Interface Descriptor:
        bLength                 9
        bDescriptorType         4
        bInterfaceNumber        0
        bAlternateSetting       0
        bNumEndpoints           0
        bInterfaceClass         1 Audio
        bInterfaceSubClass      1 Control Device
        bInterfaceProtocol      0
        iInterface              0
        AudioControl Interface Descriptor:
          bLength                 9
          bDescriptorType        36
          bDescriptorSubtype      1 (HEADER)
          bcdADC               1.00
          wTotalLength           40
          bInCollection           1
          baInterfaceNr( 0)       1
          bLength                12
          bDescriptorType        36
          bDescriptorSubtype      2 (INPUT_TERMINAL)
          bTerminalID             1
          wTerminalType      0x0201 Microphone
          bAssocTerminal          2
          bNrChannels             2
          wChannelConfig     0x0003
            Left Front (L)
            Right Front (R)
         iChannelNames           0
         iTerminal               0
« Last Edit: May 05, 2011, 12:37:27 pm by firewalker »
Offline sacherjj
« Reply #3 on: May 05, 2011, 05:26:44 pm »
Still not enough penguin in ya!   :P
Offline dmlandrum
  • The Eternal Prototyper
« Reply #4 on: May 06, 2011, 03:11:47 am »
These monitors are now listed as a discontinued product.
http://www.samsontech.com/products/productpage.cfm?prodID=1946
Just thought I'd let y'all know.
Darren Landrum
Offline Ferroto
« Reply #5 on: May 07, 2011, 12:53:56 pm »
IDK that penguin can be quite sketchy at times.
Offline ziq8tsi
« Reply #6 on: May 07, 2011, 08:30:26 pm »
You showed clearly in the video that the device uses BB/TI PCM2704 USB audio DAC.  That IC implements standard USB 1.1 Audio Device Class.  Therefore it should work, regardless of VID/PID, with any modern operating system.
The only USB devices that do not work with Linux are those with proprietary protocols.
The SMSC USB2512 is interesting, however.  Is it used to change the VID/PID, or to multiplex a second USB IC?  Is the volume control soft (via the PC) or hard (in the speaker)?  PCM2704 appears to support soft volume anyway.
Offline logictom
« Reply #7 on: May 17, 2011, 08:39:57 pm »
I've been looking for some small desk speakers and I spotted a pair of the 3i model second online but having read a review it states that it isn't great with the iphone because there is no shielding and therefore get all the usual mobile phone noises coming through.
Is it possible/easy/worth doing to retrofit some basic shielding to minimise the noise?
I'm only still considering them because they're cheap and bar the problem would be ideal for my setup.
