Author Topic: tektronix tds754A FAN  (Read 4177 times)
Offline romantaoTopic starter
  • Country: pt
« on: June 30, 2014, 10:48:32 pm »
Hi!
I recently got hold of a tektronix tds754A on ebay for a very nice price with SPC failure which i quickly repaired by changing the attenuator hybrid relays.
I noticed however that the fan is quite noisy and so i wonder if is there any fan replacement "recomended" with similar airflow rates but quieter operation noise. Found recomendations for lecroy in this forum but nothing regarding the tek 5/6/7xx.
regards
« Last Edit: July 01, 2014, 08:59:39 am by romantao »
Offline nctnico
Re: tektronix tds754A FAN
« Reply #1 on: June 30, 2014, 10:53:20 pm »
These scopes are quite noisy. If your scope has a big fan then your already have an ultra low noise version you can't even buy. But maybe somebody changed the fan. Which brand/part number is mounted in your scope?
  • Country: pt
« Reply #2 on: July 01, 2014, 08:57:20 am »
mine has a comair rotron JQ24F4V 24V 0.25A. Yes its huge!
Offline nctnico
« Reply #3 on: July 01, 2014, 01:02:56 pm »
That is the original. Unfortunately fans in that size don't come quieter. I once tried replacing such a fan with a similar sized fan from PAPST (with lots of resistors in series to reduce the speed) but that did not result in any improvement for the amount of noise.
Offline leppie
« Reply #4 on: July 01, 2014, 02:21:48 pm »
Ouch, that is huge fan... in an odd package
Wonder why the scope needs 235CFM+ airflow...
Offline dxl
« Reply #5 on: July 01, 2014, 06:13:43 pm »
Hmm, maybe add a fan speed regulation based on temperature? I own a TDS784D, and the temperature critical things are Acquisition (The DEMUX chips get really hot) and probably the Power supply.
If you ever want to hear real noisy fans, power up a HP70000 Spectrum Analyzer. :P
Offline AndyC_772
« Reply #6 on: July 01, 2014, 06:54:03 pm »
Because it dissipates about 400W, that's why. My TDS754D did a great job of keeping the lab warm in winter.
Not so much fun on a warm summer day, though.
