Author Topic: Open Source Multimeter  (Read 280620 times)
Offline Felicitus
Re: Open Source Multimeter
« Reply #325 on: January 06, 2014, 09:49:46 pm »
*shrug* I found it useful as source of some inspiration.
That's true. I tried to figure out how multimeters handle overvoltage/range switching on the ADC; some use zener diodes, but I'm not too confident with those. Also, the Fluke 27 schematic didn't shed any light on that either…
Offline mrflibble
« Reply #326 on: January 06, 2014, 10:18:26 pm »
The idea is to use clamping diodes so it doesn't go waaay out of range of what the opamp can handle. Then during integration you notice the input is out of range so you switch to a higher range, or open the switch or whatever is the appropriate action. When autoranging voltage I'd say when you detect out of range, you step to highest range, and then step down again to what is appropriate.
And the idea behind the above is that the clamping diodes only have to work for a limited time so you don't stress things too hard. The main drawback (AFAIK) behind those diodes is the leakage current during normal operations.
Offline Marco
« Reply #327 on: January 06, 2014, 10:23:42 pm »
Generally with a current limiting input resistor and clamping to the power rails (this can be done with diodes, but BJTs and JFETs are also often "abused" for this because they can have lower leakage, also a JFET mux does it for free).
Offline sync
« Reply #328 on: January 06, 2014, 11:15:45 pm »
On good meters upranging is faster than downranging, because it can detect without a full ADC cycle. And a good meter must withstand it's rated voltage on the lowest range continuously. Autoranging can be switched off. So I see no point in stepping down from the highest range.
Offline mrflibble
« Reply #329 on: January 06, 2014, 11:48:54 pm »
I see the point in stepping down if it's a DIY approach. I was making the statement within the DIY context, not the professional goodies context. Especially when you are not 100% sure yet about getting everything right, then stepping to highest range first and then slowly (while also not being in a hurry) step it down. Because not blowing shit up is more important to me than a few seconds of productivity gain. After you gain more confidence with your DIY solution you can always change the ranging algo, since that part of the software is not all that complicated.
edit: curse you typos, cuuuurse yooouuuuu
« Last Edit: January 06, 2014, 11:58:46 pm by mrflibble »
Offline sync
« Reply #330 on: January 07, 2014, 12:02:45 am »
Ok, I see your point. But what is about manual ranging then? Which is the bigger problem.
btw: I would limit a DIY DMM to 200-300V. No need to build a 1000V one.
Offline Felicitus
« Reply #331 on: January 07, 2014, 12:58:24 am »
I have checked the other OSS multimeter schematic, they're using low-leakage BAS116 diodes to effectively limit the overrange to 2.7V, which is appropriate for a 2.5V ADC input. Need to do some spice simulations to see if they handle transients well.
Offline sync
« Reply #332 on: January 07, 2014, 01:19:26 am »
I think it's not a good idea to put the ADC directly on the input. ADCs usually want a low impedance source. And a multimeter should have a high impedance input (10Mohm or more). You need an input amplifier. Then the ADC does see the transients.
Offline Felicitus
« Reply #333 on: January 07, 2014, 01:24:25 am »
That's correct, however, the input buffer can experience the transients as well (we call that "Impedanzwandler" in german, no idea if there's a direct translation).
Offline Legit-Design
« Reply #334 on: January 07, 2014, 01:58:54 am »
http://translate.google.com/#de/en/Impedanzwandler impedance converter ?
Offline mrflibble
« Reply #335 on: January 07, 2014, 04:51:44 pm »
Any specific examples of both parts and exact use of said parts to achieve this?
Offline sync
« Reply #336 on: January 07, 2014, 05:12:16 pm »
Look at the service manuals of older bench DMMs, e.g. HP 3456A, Fluke 8840A, Keithley 19x. I attached one example from the 3456A. Just four 27k resistors and two JFET diodes for clamping. These JFET are ultra low leakage, like 2N4117A.
Edit: The relay is just for range switching.
« Last Edit: January 07, 2014, 05:17:19 pm by sync »
jucole
  • Guest
« Reply #337 on: January 07, 2014, 05:14:44 pm »
Not sure if this is what you're after but Dave did a superb video on DMM input protection.
Offline mrflibble
« Reply #338 on: January 07, 2014, 06:11:54 pm »
No, that doesn't contain what I was asking about... But in the meantime I did find an answer to the question, which is to use a JFET like the 2N4117A. :) Bit expensive though.  :-\
Offline mrflibble
« Reply #339 on: January 07, 2014, 06:37:57 pm »
Lol, why didn't I notice this before? Oh wait, you edited. Or I am just blind. No matter... I got the 2N4117A from this Texas Instruments Burr-Brown appnote: http://www.ti.com/lit/an/sboa058/sboa058.pdf
But now I've got double confirmation, which is always good. :)
At any rate, given the cost I think I will stick with the BAS116 for now and when the rest is proven use the 2N4117A in the next iteration.
Edit: checked an open tab ... yup, I am blind. You already posted that 2N4117A when I replied to jucole. Need glasses.  :o Maybe you know any good price/performance MOVs as well? Or do I first have to search for those myself, and then 10 seconds before I find them you post the very part numbers I find, 100% as per Murphy's Law or some derivative? ;D Tradition dictates that you don't know any good price/performance MOVs so I will have to look for them myself. :P This would be the first project I design MOVs into, so noooo idea as of yet how to find the "good ones".
« Last Edit: January 07, 2014, 07:07:25 pm by mrflibble »
Offline Marco
« Reply #340 on: January 07, 2014, 07:29:41 pm »
I found these threads insightful :
https://groups.google.com/forum/#!topic/sci.electronics.design/HNi5Bb-rRbE
https://groups.google.com/forum/#!topic/sci.electronics.design/D53KlEoxmD8
If you want to use discretes I'd use one of the low leakage Central Semiconductor diodes (Mouser has them). You won't do significantly better by abusing discrete JFETs or BJTs. As the other thread points out though, some of the integrated MOSFET opamps can do a lot better still.
All that said, if you want to do auto-zero calibration then you need a mux, even if not muxes are cheaper and more compact than lots of relays ... the mux will probably have protection diodes built in.
« Last Edit: January 07, 2014, 07:38:35 pm by Marco »
Offline mrflibble
« Reply #341 on: January 07, 2014, 07:56:49 pm »
Thanks! Those are indeed quite informative.  :D
Do you have any specific part numbers of the ones you have in mind here, so I can stare at the datasheet?
Edit: search at mouser is not very useful for this one. "Parametric Search for Surface Mount-Diode-Ultra Low Leakage" at the centralsemi website does turn up some. Maybe you mean the CMAD6001 and such?
Same question really, part number to enable datasheet staring?  ;D
« Last Edit: January 07, 2014, 08:08:29 pm by mrflibble »
Offline Marco
« Reply #342 on: January 07, 2014, 08:16:57 pm »
The thread mentioned the CMPD6001S, but just look up all the central semiconductor diodes on mouser there are a couple with similar specs.
As for muxes, in another thread someone mentioned the MAX4051 since Maxim gives a typical leakage current of 2 fA ... that said, Ti/On semiconductor have versions of the 4051 at a fraction of the cost with a typical 10 fA in the datasheet.
« Last Edit: January 07, 2014, 08:18:36 pm by Marco »
Offline mrflibble
« Reply #343 on: January 07, 2014, 08:32:15 pm »
Thanks for the confirmation. Search on centralsemi.com turns up basically CMxD6001...
So not the CD4051B then?
Offline Marco
« Reply #344 on: January 07, 2014, 08:40:57 pm »
10 fA typical at room temperature.
Offline sync
« Reply #345 on: January 07, 2014, 08:46:39 pm »
10pA not fA.
Offline sync
« Reply #346 on: January 07, 2014, 08:49:41 pm »
What are your requirements? Voltages, resolution, ...?
A CD4051 should be fine for a 3-4 digits meter and probably a disaster for a 6.5 digits one.
« Reply #347 on: January 07, 2014, 08:59:35 pm »
10pA more like it, but clean the package, clean the board and have soldermask and guard traces and it is likely to go a lot lower.  Drop supply voltage to 15V and it will be worse, as this is likely specced at the best conditions.
Offline mrflibble
« Reply #348 on: January 07, 2014, 10:59:15 pm »
I wasn't planning on using the CD4051B. I just linked to it to check where Marco got those awesome leakage figures for a 4051 device. But an oopsie of 3 orders of magnitude would explain things.
Offline mrflibble
« Reply #349 on: January 07, 2014, 11:01:59 pm »
Also pre-assembly cleaning? Or just the whole assembled board? If pre-assembly, any handy tips? Usual procedure would be to put it in an IPA filled ziplock bag in warm water in an ultrasonic bath, but maybe there's better ways?
