Author Topic: Is there a proper name for this particular cover/plug/pin/bung?  (Read 951 times)
Offline HalcyonTopic starter
A bit of an odd one... I'm after a flexible/compliant rubber or silicone "plug" with a flat head that I can just push-fit into small holes in both timber and metal, to essentially cover and disguise the hole. Similar to the little end-pins you get with some ESD tubes to keep IC's from falling out the ends. I don't know if there is a proper name for these or if anyone can suggest a product they've used in the past.
The holes are approximately 3.5 to 4.0mm in diameter.
Offline 44kgk1lkf6u
Re: Is there a proper name for this particular cover/plug/pin/bung?
« Reply #1 on: April 11, 2024, 03:12:42 am »
Searching for ribbed plug yielded some results.
Offline notsob
« Reply #2 on: April 11, 2024, 03:18:12 am »
Try google for "blind hole plug"
Online abeyer
« Reply #3 on: April 11, 2024, 03:30:12 am »
yeah... for certain types of holes that need plugging.
The following users thanked this post: 5U4GB
Offline shabaz
« Reply #4 on: April 11, 2024, 04:14:06 am »
I believe the technical term (as Beavis & Butthead would also describe it) is, as you say, a bung.
There are silicone bungs (photo below), or, if you don't want that level of softness, perhaps plastic blind rivets (or variants such as the ones in the photo below) might suit your needs. Those plastic rivets are really handy for all sorts of purposes, e.g. keep two sheets joined together, but they could also just be used as a plug.
This site has a lot of the plastic options.
For full flushness, there are rubber tapered plugs (photo of those below too).
« Reply #5 on: April 11, 2024, 07:54:15 am »
Easiest is a tube of acrylic or silicone sealer, and wipe over the hole to leave a blob in the hole, and wipe after with a damp cloth. Fast, cheap, and works well.
« Reply #6 on: April 11, 2024, 10:38:25 am »
In this instance I want it to be removable.
I ended up finding something (which I hope works) listed under "Snap in locking hole plugs, rubber panel seal cover flush type panel round for kitchen rubber bulkheads waterproof sealing plugs" (read in Big Clive's voice).
Offline EPAIII
« Reply #7 on: April 12, 2024, 06:24:47 am »
Rubber corks?
Paul A.  -   SE Texas
And if you look REAL close at an analog signal,
You will find that it has discrete steps.
Offline armandine2
« Reply #8 on: April 12, 2024, 07:00:26 am »
« Last Edit: April 12, 2024, 07:02:30 am by armandine2 »
Funny, the things you have the hardest time parting with are the things you need the least - Bob Dylan
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #9 on: April 12, 2024, 08:10:19 am »
Brings to mind such as these,
https://www.mcmaster.com/products/hole-covers/protective-plugs~/
of course YMMV, you'll probably want to find your local equivalent as McMaster is fairly US-specific IIRC, but as a list of examples, that's fine.
Seven Transistor Labs, LLC
