Author Topic: Transistor amplifier  (Read 4297 times)
Offline yalectTopic starter
« on: March 01, 2015, 09:49:39 am »
I would like to ask you about my following circuit, some use it like RF part.
What is the roll of the capacitor C4?
C2 is for positive feedback how it’s calculated and if we increase the value
Of L1 connected to the emitter of the transistor, the feedback will increase?
Thank you
« Last Edit: December 13, 2021, 07:46:46 pm by yalect »
Online MK
Re: Transistor amplifier
« Reply #1 on: March 01, 2015, 12:27:40 pm »
Looks like an oscillator to me
« Reply #2 on: March 01, 2015, 01:37:07 pm »
Perhaps this should have been posted in the beginners section.
Yes it looks like an oscillator.
Have you built the circuit?
« Reply #3 on: March 01, 2015, 03:11:43 pm »
Yes, it looks like oscillator and work as Colpitts oscillator but it’s a main part used for RF receiver
Thanks
« Reply #4 on: March 01, 2015, 05:47:30 pm »
Thanks
Do you have the full schematic?
I don't see how it's Colpitts which uses a tapped capacitor for feedback.
It looks like a regenerative receiver. Q1 appears to be configured in common base with R5 and C6 forming a low pass filter with a cut-off of 23.4kHz which will block the RF on the output.
Presumably R1 reduces the Q of the tank circuit so it doesn't oscillate continuously.
« Last Edit: March 01, 2015, 05:53:48 pm by Hero999 »
« Reply #5 on: March 02, 2015, 07:34:55 am »
Thank you for your reply
There are some circuit have the same work base of the Colpitts oscillator but not using a taped capacitor the feedback takes a way from the collector directly
That circuit feeding second transistor throw the low pass filter (R5,C6) Q2 configured in common emitter, the filter takes it’s signal from the collector of the Q1 with LC circuit which is the output of the oscillator, C4 maybe for negative feedback
What about the value of C2 how it’s calculated and increasing the L1 will increase the value of positive feedback
« Reply #6 on: March 02, 2015, 11:09:10 am »
Are you talking about the typical kind of transmitter used in simple wireless microphones?
It's not Colpitts. It looks like it is but it isn't because the feedback is not taken from the centre tap.
Here's a link to a site which gives a more detailed description of the oscillator circuit and how to calculate the values.
http://sm0vpo.altervista.org/begin/bug_calc.htm
Bear in mind that the circuit you posted is probably set up so it will not oscillate, unless there's an external signal.
Offline Paul Price
« Reply #7 on: March 02, 2015, 10:07:14 pm »
The poster's original circuit is a schematic of  a super-regenerative FM receiver first published in Popular Electronics or Radio-Electronics magazine? around 1957-1958 with a then new hot RF transistor like a 2N502A or 2N384 that was able  to work at these 100mHz+ high frequencies.
C4 feeds back a portion of the RF carrier when tuned to  a FM channel  to the base of the transistor and so the FM is slope-demodulated by the germanium diode D1 and  the demodulated audio is amplified by the transistor. The function of R1 is to both provide a audio frequency  output load to the transistor and also voltage divider for the RF feedback to the base.
R5 and C6 are a low-pass filter for the audio output, could easily drive a crystal earphone to a very hear able volume.
I built one of these a few years ago and the sensitivity and sound quality is really fantastic for such a simple circuit.
Whoever thought up this simple circuit was a genius! The values of the original circuit were optimized for best performance.
Value of the RF choke in the emitter circuit is critical and had been optimized, and in the original circuit the choke was made by winding #32 wire around a resistor,  so it was bypassed by a 100-ohm to 470 ohm resistor.  Too little or too much inductance here and it just won't work.
« Last Edit: March 02, 2015, 10:16:50 pm by Paul Price »
