Thank you
@norbert.kiszka!
Your work on the MHO900 (and Rigol in general) is MUCH appreciated! If you can, please keep up your work
(On my MHO954: The larger display area alone is worth the price for your mod.)
Question:
Self-CalIt seems, that in mod 0.1.2 the self cal has options too choose from, which do not exist in the stock self-cal.
- At least 4 options are not checked after installing - does that mean, that is what the stock self-cal does?
- when checking ALL options, self-cal fails after <1min (4%). Is that expected? Do some self-cal items require external connections, i.e. some (BNC) cables?
Wishlist:
1. Customize Shortcuts (top right): Ability to remove certain buttons
1b. if 1) not possible, would you mind [adding an option] to remove all shortcuts, that are directly accessible via hardware buttons?
(i.e. run/stop, Measure, navigate, ...)
2. Pressing the Default button: load `DEFAULT.stp` instead of the rigol hard coded default settings?
(Allows to customize own defaults)
2b. if 2) is not feasible: Can we change hard coded default, so all channels are configured for 10x?
Thanks again & best regards from Austria,
Florian
