Author Topic: gain control for 100Mhz  (Read 17324 times)
Offline navidrctTopic starter
« on: October 12, 2015, 06:17:01 am »
hi
i build a function gen that its output frequency is about 100 MHz
i want the amplitude of wave be variable
maybe i use gain control but its expensive
i want something cheap.
anybody know a way?
Offline JoeB83
  • Longmont, CO
Re: gain control for 100Mhz
« Reply #1 on: October 12, 2015, 06:22:35 am »
I think we need more information about your project in order to help you.
« Reply #2 on: October 12, 2015, 06:32:50 am »
100 MHz . a lot of wave type . output must be between 12 and -12 .
u think of sine wave that its swing between -5 and 5
notice that i have -12 and 12 by power supply .
Offline JoeB83
  • Longmont, CO
« Reply #3 on: October 12, 2015, 06:48:26 am »
Can you share a schematic?
« Reply #4 on: October 12, 2015, 06:51:10 am »
it does not matter
i have 100MHz wave that i want be variable.do u know a way that its cheap?
Online vk6zgo
« Reply #6 on: October 12, 2015, 07:14:59 am »
Offline tggzzz
« Reply #7 on: October 12, 2015, 07:44:12 am »
it does not matter
Yes it does matter.
Yes I do know a way that meets your very vague requirements.
You would be well advised not to tell people that know about these things that the answers to their questions do not matter.
Online vk6zgo
« Reply #8 on: October 12, 2015, 07:49:04 am »
PIN diode.
http://www.radio-electronics.com/info/rf-technology-design/attenuators/rf-variable-pin-diode-attenuator.php
i don't think that it will be good solution for function gen that has 100 MHz bandwidth
I'm not saying to use that exact design,but PIN diode circuits are widely used as attenuators.
One I've worked on was at 433MHz.
In his original post,he did say 100MHz signal,not bandwidth.
OK,I should have realised what he meant when he said "function generator".
Offline Fungus
« Reply #9 on: October 12, 2015, 08:08:15 am »
Potentiometer?
Offline tron9000
  • Still an Electronics Lab Tech
    • My Hack-a-day project page
« Reply #10 on: October 12, 2015, 08:30:01 am »
it does not matter
+1 tggzzz,
No Schematic, no dice - http://tron9000.blogspot.co.uk/2015/05/its-all-in-your-head.html
Partsbox.io - orangise your parts!
"If you're green you can only ripen. If you're ripe you can only rot!"
Offline daqq
  • Country: sk
    • My site
« Reply #11 on: October 12, 2015, 08:36:45 am »
Define cheap. The cheapest way is to simply scale your DAC input data and trade amplitude control for loss of resolution. Depending on your DAC input type you can scale the input (reference) voltage. Variable gain amplifiers are another option. Attenuators (relay based, solid state) can get pricey, but you can scale without resolution loss over several decades when done properly.
« Reply #12 on: October 12, 2015, 08:43:31 am »
my DAC output full range is 30mA
in attachment u can see
Offline oldway
« Reply #13 on: October 12, 2015, 09:20:58 am »
It seems to me that what you need is an adjustable 50R output amplifier for your function generator.
Offline tggzzz
« Reply #14 on: October 12, 2015, 09:45:54 am »
Your spec keeps on changing.
First it is 100MHz, then 100MHz bandwidth, and I suspect even that isn't correct (it certainly isn't accurate).
First it is single-ended voltage, then you introduce differential current.
You should do research on "differential transimpedance" and "reconstruction filter".
« Last Edit: October 12, 2015, 10:03:45 am by tggzzz »
Offline tggzzz
« Reply #15 on: October 12, 2015, 10:04:47 am »
« Reply #16 on: October 12, 2015, 10:34:28 am »
u mean digital resistor?
if yes
that wont work cause that cant support 100 MHz
Offline KJDS
    • my website holding page
« Reply #17 on: October 12, 2015, 10:54:22 am »
if u mean digital resistor
that wont work
cause 100 MHz cant be supported by DR
and its not working
What makes you think that a suggestion of an adjustable amplifier can mean a digital resistor?
« Reply #18 on: October 12, 2015, 10:56:42 am »
sorry sorry that was my mistake
max freq is 100MHz
« Reply #19 on: October 12, 2015, 10:59:06 am »
that wont work
and its not working
then you mean voltage gain control that i said before its so expensive
Offline daqq
  • Country: sk
    • My site
« Reply #20 on: October 12, 2015, 11:30:43 am »
OK, could you please define expensive? 1 USD? 3 USD? 5 USD? 10 USD? 20 USD?
Offline Fungus
« Reply #21 on: October 12, 2015, 11:35:20 am »
You want a 100MHz amplifier that isn't expensive?  :-DD
You're doing it wrong. But we have no idea what you're actually doing so we can't help.
I declare this thread finished until you provide a schematic.
« Reply #22 on: October 12, 2015, 12:17:07 pm »
|O i want variable voltage control amplifier not just an amplifier  |O
Offline oldway
« Reply #23 on: October 12, 2015, 12:24:20 pm »
Please post in the beginner section, you seems to be a beginner.
Offline oldway
« Reply #24 on: October 12, 2015, 12:26:50 pm »
if yes
Did you ever look at a schematic of a function generator ?
