>>Will it be a similar design to your current machine?
Based on HP machine technology but completly different frame setup
>>Will it have rail/conveyor system?
Conveyor system is possible as upgrade option
>>What is the reason for using pneumatic feeders, and advantage over elec/mech type?
The price and easy interface??? and you can buy from different sources! professional design!
Well tested and reliable technology and modular design you can take out the complete feeder carrying the wheel!
Yamaha CL feeder from 8mm up to 56mm wide
>>Screw thread ball drives?
Same as HP machine yes
>>Encoders?
Same as HP machine feed back servo drive no extra linear encoders planned
>>Aluminium or granite bed?
granite bed
yes need to place 50000cph
Aluminium machine based on a frame contruction closed working area build in Germany.
>>Existing software like current machines?
yes we use the same
>> What month 'later his year'?
I told you we release END of the year!
