Author Topic: Batteroo testing  (Read 281732 times)
Online dexters_lab
Re: Batteroo testing
« Reply #450 on: January 06, 2017, 01:42:20 pm »
i forgot there was a separate thread for testing so i'll repost my last two messages here in case they were missed on the other thread:
The ic could be the same, but the layout looks different to the AAA Batteriser:
https://www.eevblog.com/forum/projects/batteroo-testing/msg1097209/#msg1097209
It would be interesting to see if the circuit is identical.
The pinout looks similar, but the AA Batteriser has 2 inductors.
Could you measure if both inductors are connected in parallel or if there are two independent boost conveters? You probably have to remove one inductor when doing the measurement, because both inductors are connected to the same input voltage.
the inductors are NOT in parallel looks like each one has it's own connection to the IC
Offline Hensingler
« Reply #451 on: January 06, 2017, 02:07:07 pm »
You measured they are not connected? Assuming pin 1 is top left pins 3 and 6 and 4 and 5 being common would explain AAA and AA layouts. If pins 3 and 6 are not common then maybe it is some kind of bi-phase converter.
Online dexters_lab
« Reply #452 on: January 06, 2017, 02:17:47 pm »
i measured them, there's actually about 51kohm between 3 and 6 with only the IC in circuit
Offline bktemp
« Reply #453 on: January 06, 2017, 03:02:19 pm »
Thanks for measuring.
If the second channel behaves identical to the single channel one on the AAA Batteriser, the maximum output current should be around 1.5A.
Some measurements would be interesting:
Operate both channels at the same time, are they interleave or is the second channel only enabled at higher output currents?
Online dexters_lab
« Reply #454 on: January 07, 2017, 04:12:36 pm »
i found 30 mins or so today to do a little testing and measuring.
Setup is as follows:
PSUA (Supply), HP 6632B, CV mode supplying the Batteriser input voltage
PSUB (Load), HP 6632B, CC mode loading/sinking the Batteriser output fixed at 125mA
Both PSUs have the sense wires connected, PSUA has them inside the beige box to the banana posts, PSUB has them to the back of the banana plugs. So there will be some losses in the bits in between like plugs, clip, wire to the batteriser etc (see the attached pic).
A: PSUA +
B: PSUA -
C: PSUB +
D: PSUB -
E: Black Wire: Common (B & D) to - battery terminal on Batteriser PCB
F: White Wire: + Battery terminal on Batteriser PCB
G: Red Wire: Output terminal on Batteriser PCB
H: The Batteriser PCB
Initial observations:
Above 1.45v the batteriser just passes through the V_In to V_Out with negligible losses
Below 1.45v the batteriser seems to turn on and provide an increasing boost to V_Out as the V_In drops
At 125mA load the batteriser wont startup below 0.6v, but it will continue to run if it's running and you then reduce the V_In, the lowest i measured to was 0.5v, i figured there would be little point less than that anyway. If it doesn't start up, it just passes through V_In to V_Out.
I should have a little time tomorrow to do some more, if anyone has a specific suggestion or spotted a mistake i've made let me know. Hopefully it should correlate to other peoples measurements!
Values have been rounded!
V_in   I_in   V_out   I_out   V_Boost
1.50   0.13   1.49   0.126   -0.02
1.45   0.13   1.44   0.126   -0.02
1.40   0.15   1.47   0.126   0.07
1.35   0.16   1.46   0.126   0.11
1.30   0.16   1.45   0.126   0.14
1.25   0.16   1.44   0.126   0.18
1.20   0.16   1.42   0.126   0.22
1.15   0.17   1.40   0.126   0.25
1.10   0.17   1.38   0.126   0.28
1.05   0.18   1.36   0.126   0.31
1.00   0.19   1.34   0.126   0.34
0.95   0.19   1.31   0.126   0.37
0.90   0.20   1.29   0.126   0.39
0.85   0.21   1.26   0.126   0.41
0.80   0.21   1.23   0.126   0.43
0.75   0.22   1.20   0.126   0.45
0.70   0.23   1.16   0.126   0.46
0.65   0.24   1.13   0.126   0.47
0.60   0.26   1.08   0.126   0.49
0.55   0.27   1.05   0.126   0.49
0.50   0.29   1.00   0.126   0.50
« Last Edit: January 07, 2017, 07:00:17 pm by dexters_lab »
The following users thanked this post: SeanB, Kean
Offline sync
« Reply #455 on: January 07, 2017, 04:25:44 pm »
I think your efficiency calculation is wrong.
V_in   I_in   V_out   I_out   V_Boost   %Eff
1.50   0.13   1.49   0.126   -0.02   100.1
(1.49 * volt * (0.126 * ampere)) / (1.5 * volt * (0.13 * ampere)) = approx. 0.96276923
1.00   0.19   1.34   0.126   0.34   67.0
(1.34 * volt * (0.126 * ampere)) / (1 * volt * (0.19 * ampere)) = approx. 0.88863158
Offline Kean
    • Kean Electronics
« Reply #456 on: January 07, 2017, 04:49:16 pm »
Agreed.
Using those measurements for I_out=126mA, I calculate
Min(%Eff)=85.2% at V_in=1.35V
Max(%Eff)=96.3% at V_in=1.5V
Offline FrankBussTopic starter
    • Frank Buss
« Reply #457 on: January 07, 2017, 04:54:59 pm »
You should solder the sense wires to the Batteriser. I measured 1.418 V for 1 V input, at 100 mA. 78 mV difference compared to your measurement is a bit high, maybe I did something wrong, too, but to be sure it should be done right. I guess there is some variation, which might be a good idea to measure, too, but 5% (relative to 1.5 V) is a bit high. My multimeter should measure much better than 1%.
And maybe post a CSV file or a Google spreadsheet, then it is easier for others to use your data, draw graphs etc. My data:
http://www.frank-buss.de/batteroo/batteroo.csv
The following users thanked this post: Kean
Online Fungus
« Reply #458 on: January 07, 2017, 05:09:26 pm »
1.25  0.16  1.44  0.126   0.18    76.6
This is really the most important voltage range, it's 80%(ish) of a normal battery's life.
75% efficient on a fairly light load? Oh, dear...
Edit: Nope, your sums are wrong. (1.44*0.126)/(1.25*0.16) = 90% efficient.
« Last Edit: January 07, 2017, 05:15:48 pm by Fungus »
Offline samgab
« Reply #459 on: January 07, 2017, 05:10:09 pm »
Thank you dexters_lab... Perhaps the same type of testing repeated but at various different load levels, like 500mA, 1A, 1.5A, 2A... See how it performs under some real load! Cheers!
Offline Marcel_X
« Reply #460 on: January 07, 2017, 05:36:00 pm »
1.45   0.13   1.44   0.126   -0.02   100.1
1.40   0.15   1.47   0.126   0.07   84.8
1.35   0.16   1.46   0.126   0.11   79.4
1.30   0.16   1.45   0.126   0.14   77.1
1.20   0.16   1.42   0.126   0.22   76.9
1.15   0.17   1.40   0.126   0.25   74.5
1.10   0.17   1.38   0.126   0.28   72.1
1.05   0.18   1.36   0.126   0.31   68.6
0.95   0.19   1.31   0.126   0.37   65.0
0.90   0.20   1.29   0.126   0.39   63.3
0.85   0.21   1.26   0.126   0.41   61.1
0.80   0.21   1.23   0.126   0.43   59.3
0.75   0.22   1.20   0.126   0.45   56.8
0.70   0.23   1.16   0.126   0.46   54.3
0.65   0.24   1.13   0.126   0.47   51.9
0.60   0.26   1.08   0.126   0.49   49.1
0.55   0.27   1.05   0.126   0.49   46.5
0.50   0.29   1.00   0.126   0.50   43.6
Thanks for measuring. Corrected the last column for you.
Results are similar to Frank's measurements.
V_in   I_in   V_out   I_out   V_Boost Eff%
1.50   0.13   1.49   0.126   -0.02    96.3
1.45   0.13   1.44   0.126   -0.02    96.3
1.40   0.15   1.47   0.126   0.07     88.2
1.35   0.16   1.46   0.126   0.11     85.2
1.30   0.16   1.45   0.126   0.14     87.8
1.25   0.16   1.44   0.126   0.18     90.7
1.20   0.16   1.42   0.126   0.22     93.2
1.15   0.17   1.40   0.126   0.25     90.2
1.10   0.17   1.38   0.126   0.28     93
1.05   0.18   1.36   0.126   0.31     90.7
1.00   0.19   1.34   0.126   0.34     88.9
0.95   0.19   1.31   0.126   0.37     91.4
0.90   0.20   1.29   0.126   0.39     90.3
0.85   0.21   1.26   0.126   0.41     88.9
0.80   0.21   1.23   0.126   0.43     92.3
0.75   0.22   1.20   0.126   0.45     91.6
0.70   0.23   1.16   0.126   0.46     90.8
0.65   0.24   1.13   0.126   0.47     91.3
0.60   0.26   1.08   0.126   0.49     87.2
0.55   0.27   1.05   0.126   0.49     89.1
0.50   0.29   1.00   0.126   0.50     86.9
If it weren't for C, we'd be using BASI, PASAL, and OBOL
The following users thanked this post: dexters_lab
Online Fungus
« Reply #461 on: January 07, 2017, 05:40:01 pm »
OK, now we need a graph of that with overlaid graphs at different currents.
Online dexters_lab
« Reply #462 on: January 07, 2017, 06:00:24 pm »
thanks, i always make a goof somewhere, i'll edit my post!
Offline razvanme
« Reply #463 on: January 07, 2017, 07:41:32 pm »
The patent mentioned ~1.34 volts on the majority of devices as cutoff if I remember correctly. Meaning if the battery is at 1V (depending on load) it will not work anymore. So until 0.8V the energy left is "untapped" . So much for "extract all energy".
Online dexters_lab
« Reply #464 on: January 08, 2017, 10:24:56 am »
Testing at 100, 250 & 500ma complete
i opted not to change my setup, the sense wires are soldered into my banana plugs on PSUA, you might be able to see the small white sense wire tucking into the back of the plug in the pic, it would mean cutting them or fiddling around the back of the PSU to attach other sense wires and i don't really want to do that. What i did do though is reduce the length of my wires to the batteriser, made sure everything had a good connection etc and started again from scratch, so there should be a small improvement in the losses.
So my sheet now has 100mA, 250mA & 500mA, i also un-rounded the numbers and corrected the efficiency calculation and dropped them into a google spreadsheet.
Note row 64, 0.502v input at 500mA load caused the batteriser to shut down
https://docs.google.com/spreadsheets/d/1U5cLitpeP6SIjv9UzhVOiniEQ6ENosAY_12V6MUlb7E/edit?usp=sharing
E&OE, YMMV etc  ;D
« Last Edit: January 10, 2017, 10:19:01 am by dexters_lab »
The following users thanked this post: Kean, dr_frost_dk
Offline EEVblog
« Reply #465 on: January 08, 2017, 10:52:48 am »
Of course I wasn't serious, but the test is to compare the power output of the two devices, so the added weight means that the train running times/laps are not 100% comparable because the trains have different weights.
I'm pretty sure the Batteriser weight would be within the normal weight tolerance of the batteries themselves.
Offline JiggyNinja
« Reply #466 on: January 08, 2017, 09:51:46 pm »
Charts of Dexter's data attached!
Actually looks far more interesting than I thought it'd be. The Input/Output voltage graphs for all 3 graphs have the exact same shape, so exact that after making the first two I had to double-check the tables to make sure I hadn't copy+pasted something wrong.
Of course, this is running off of a high-grade power supply, and as we all know from Batteroo, you can't simulate a battery with a power supply because that ignores the batteries internal resistance.
Never mind the fact that adding the IR into the model will make the sleeve perform far worse than these ideal characterizations. Don't worry yourself over such a minor detail.  :palm:
    • Frank Buss
« Reply #467 on: January 09, 2017, 01:41:15 am »
You don't need to cut anything, you could just use a multimeter to measure it. The problem with your setup is that you don't know how much it is wrong. As you can see in Dave's video, it can be 0.2 V for 100 mA, depending on contact resistance etc. :
But probably it is not that much for your setup, because the voltages are very similar for different loads, which is consistent with my tests. Sorry for nitpicking again :)
Offline samgab
« Reply #468 on: January 09, 2017, 03:31:52 am »
Yes, I really do appreciate the testing and it's yielded some interesting results, but from experience, you can get pretty inaccurate results due to voltage drop if the sense wires aren't exactly at the point of measurement. It's really the whole point of having sense wires.
But having said that, I was quite impressed by the performance of the sleeve under this test up to 500mA at least. Good efficiency curves. Thanks to the user JiggyNinja who created graphs. I'm still curious to see how it does with a real load on it. Lots of devices powered by AA cells will draw 1A, 2A, and upwards.
Offline TechnicalBen
« Reply #469 on: January 09, 2017, 11:25:40 pm »
You can turn the train upside down, have a roller "road" (track on a spindle also upside down). Though technically, due to the testing location, by some reference frames, the test was already upside down! ;)
Online dexters_lab
« Reply #470 on: January 10, 2017, 10:18:20 am »
I took the time out just now to re-wire the setup so i now have the two PSUs connected with the sense wires right onto the batteriser PCB, i verified it with my bench DMM and can't see any appreciable difference from my bench PSU display so this should be as good as i can get it with the equipment i have.
This is the new sheet with additional data for 750mA and new more accurate data for the 100, 250 and 500ma range
i removed the entries when the batteriser shuts down, so you'll see the 750mA data only goes to .649v as that is the lowest i could go.
Note i have removed the links to the previous results
« Last Edit: January 16, 2017, 12:25:57 pm by dexters_lab »
The following users thanked this post: samgab, Kean, Marcel_X
Offline JiggyNinja
« Reply #471 on: January 10, 2017, 01:44:45 pm »
Charts!
The following users thanked this post: dexters_lab, samgab, Kean, Marcel_X, dr_frost_dk
Offline samgab
« Reply #472 on: January 10, 2017, 04:53:02 pm »
Charts!
I hope you don't mind, I had a little play and did a couple of overlaid charts which show all current rates overlaid:
I think the results, the batteroo performance, looks pretty good from this data.
« Last Edit: January 10, 2017, 08:39:53 pm by samgab »
The following users thanked this post: dexters_lab, Kean, daveake
Online dexters_lab
« Reply #473 on: January 10, 2017, 05:12:03 pm »
is there anyone else doing similar testing to confirm/reproduce?
Dave is still swanning around his private beach so not likely to see anything from him for a while
Offline bktemp
« Reply #474 on: January 10, 2017, 05:26:54 pm »
The results look plausible: Since the boost converter always works in PFM mode, the duty cylce and peak current are constant over the load range, therefore there should be almost no change in efficiency like the typical curve you see in the more common PWM mode boost converter specs. The slight drop at high current and low input voltage is probably the voltage drop at the input wires, because you didn't connect the sense wires directly at the Batteriser pcb.
