Author Topic: Looking for some waveguide expertise here  (Read 2779 times)
Offline wkbTopic starter
« on: May 11, 2017, 09:51:43 am »
Picked this up at a local ham fest.  Not being a microwave nut by any stretch of imagination I wonder what this stuff does? OK, horn antennes but
there is more to it.  Maybe something with polarisation ?? No clue..
Hope the images are enough clue to the initiated...
Re: Looking for some waveguide expertise here
« Reply #1 on: May 11, 2017, 09:52:52 am »
more pics
Offline kazam
« Reply #2 on: May 18, 2017, 09:51:24 pm »
45 degree polarization
Septum could be cross-polarization suppression. CP polarizer if made of metal but doesn't look like it.
Dielectric around edges I'm not sure but could be far-field sidelobe suppression. Or cross-pol. Or both!
Radome is most likely just for protection or to keep pressurized air inside. This prevents dust from entering the waveguide.
Looks like radar stuff for X-band. 10GHz.
Offline radar_macgyver
« Reply #3 on: May 19, 2017, 06:17:34 am »
That's a double ridge waveguide. The ridge increases the bandwidth that the waveguide can transmit without multiple modes (ie, without dispersion). Same goes with the ridges inside the horn flare - these extend the bandwidth of the horn. They work just like a Vivaldi antenna. You don't often see double ridge waveguide in radar, so this could be X-band satcom equipment, or EW or radar warning receiver antennas. Very cool find!
Edit: septum polarizers are not normally flared, they usually have a 'stair-step' appearance. They're used to create circular polarization. You'll often find them inside satellite TV LNBs.
« Last Edit: May 19, 2017, 06:20:05 am by radar_macgyver »
Offline cj
« Reply #4 on: May 29, 2017, 08:54:12 am »
Looks like the parts you have are from this type of feedhorn.
CJ
« Last Edit: May 29, 2017, 09:45:32 am by cj »
« Reply #5 on: May 29, 2017, 07:31:02 pm »
The Heelweg picture shows a very similar but a lot bigger horn.
Wilko
