Author Topic: Analogue IC design engineer role?  (Read 2023 times)
Offline FaringdonTopic starter
« on: January 25, 2023, 04:24:55 pm »
Is it correct that general analog hardware electronics engineers, who can design analog circuitry and SMPS,  cant go for Analogue IC design engineer roles?
'Perfection' is the enemy of 'perfectly satisfactory'
Offline Slh
Re: Analogue IC design engineer role?
« Reply #1 on: January 25, 2023, 04:34:36 pm »
Anyone can go for any role.
All roles have a number of filters on the way. The first is the person applying.
As someone with no experience in the analogue IC design field, I'd expect the filters to be harsher if the analog hardware engineer who can't decide how to spell analogue is applying for a more senior role.
The following users thanked this post: MK14, Faringdon
Offline SiliconWizard
« Reply #2 on: January 26, 2023, 03:00:55 am »
Uh. The question is, do you know anything about IC design?
The following users thanked this post: maxpayne, Gyro, Faringdon
« Reply #3 on: January 29, 2023, 12:36:19 am »
I was at a big lighting co and their  engineers were designing the circuit to go on a chip....they were making their own LED driver ICs........so they were doing the circuit bit, and the IC engineers would later implement it on a chip.
So i guess theres both roles in an Analogue IC design company?
I cannot see how anyone can implement a circuit on an IC, without having worked for years as a hardware engineer first, designing circuits....i mean, how would someone who always worked  in an IC fab plant, ever get the circuit design experience needed?
I would have thought Analogue IC design co's would want to steel hardware design engineers from industry all the time?....and then train them up in the ways of implementing the circuits on an IC.....ie, training them up on Allegro or whatever?
« Last Edit: January 29, 2023, 12:38:20 am by Faringdon »
Offline Gyro
« Reply #4 on: January 30, 2023, 06:41:56 pm »
If you are interested, then why don't you just apply? If you get filtered out then you get filtered out - just be completely honest on your CV / application. I don't think anyone here can tell you whether to apply or not, it depends how desperate they are.
« Last Edit: January 30, 2023, 06:45:07 pm by Gyro »
Best Regards, Chris
Offline AnalogTodd
« Reply #5 on: February 05, 2023, 06:36:08 pm »
There are people that can easily swap roles, such as going from a general hardware engineer to an IC design engineer. There are people who get out of school and immediately go into analog IC design. I know, I did that and have been doing it for almost three decades. From there, there are people who cannot make that switch either.
With all of that said, there is often much more difficulty in going from generalized roles to more specialized roles as opposed to the other direction. One of the beauties of having someone go from straight out of school into the IC design role is that the general hardware gets taught via mentoring at the same time as all of the other relevant skills. There is a LOT of additional specialized knowledge that has to be learned to go into IC design as opposed to general hardware design. Even within a field like analog IC design, there are specializations that go even further down.
There is a lot that needs to be covered in school to get someone ready for going into general analog hardware design. Starting of course is circuit basics such as RLC equations, transistor basics, building blocks like op amps, logic, etc. that all eventually go into specialized circuits like a switching supply or a signal acquisition board. To go into IC design, now you need to get deeper into transistor level circuitry, covering things like crystal structure, diffusions and device physics. Depending on the school you go to, you will find it easier or harder to get into these courses. Not only that, but the development of technology over the years has made it such that it now usually requires master's level study to get this education compared to decades prior.
Once you actually get out of school and into a role, understand that you don't just get turned loose to do the job. The rule of thumb we used is that it took five to seven years of mentoring before a new grad would be prepared to be working without major oversight. First projects were almost never full chip designs, but instead being given an existing circuit to make changes to in order to create a new product--imagine taking a 1A buck regulator and changing it to now be a 3A buck regulator or changing it to run at lower operating currents. This gives one a chance to learn transistor level building blocks, chip layout, and eventually circuit debug in the lab (which give the general hardware experience).
As for working at an analog IC design company, there are many different roles available. The IC designer is often the toughest role as they need to understand (to some degree) every other role, starting from process engineering at the base level, to IC design, to layout, to packaging, test, and finally application level. Each of those other roles ends up being a different person they interface with in the course of their duties.
If you have questions, let me know.
Lived in the home of the gurus for many years.
The following users thanked this post: Kean, MK14
Online tggzzz
« Reply #6 on: February 05, 2023, 10:38:52 pm »
Before you talk to anyone in the company recruiting staff, I suggest you compare and contrast end user applications engineering, systems engineering, analogue engineering, ic design engineering, analogue ic design engineering. Having done that you will be able to explain how your considerable experience matches their requirements.
And that neatly segues into what do you think are the mandatory technical competency requirements for such a position? If you can't answer that you will be at a disadvantage.
The following users thanked this post: Faringdon
