Author Topic: Electronic Engineering Research Technician Canterbury UK  (Read 3275 times)
Offline atbukcTopic starter
« on: May 31, 2018, 10:26:58 am »
The School of Engineering and Digital Arts is seeking to recruit a Research Technician to undertake technical electronics support to deliver the goals and milestones of research and enterprise projects undertaken by the School and to ensure the success of these projects.
Specifically, you will provide electronics design, fabrication and testing support, liaising with project stakeholders.
http://www11.i-grasp.com/fe/tpl_kent01.asp?newms=jj&id=41825&newlang=1
Come and join the team!
Offline YTusername
    • Atadiat
Re: Electronic Engineering Research Technician Canterbury UK
« Reply #1 on: June 02, 2018, 12:30:49 pm »
Do you support candidates with visa process?
best
« Reply #2 on: June 04, 2018, 11:43:40 am »
Yes, if you are entitled to work in the UK we would consider an application from you, I have viewed your CV and your skill set could fit well in the role.
There is some helpful information here.
https://www.kent.ac.uk/human-resources/immigration/prospective-employees/without-right-to-work.html
PM me if you need any more info.
