Author Topic: Small job - modification of existing PCB from OSHPARK  (Read 1956 times)
Offline devedTopic starter
  • Country: cz
« on: December 10, 2020, 07:26:28 pm »
Hello,
I need to make modification on this PCB:
https://oshpark.com/shared_projects/JEp3Wx4B
(remove one 7135 regulator on the bottom and add a SMD diode with resistor)
If interested, please contact me to dicuss the conditions  :-+
Thank you!
Lubos
Offline UnHappy
  • Country: in
Re: Small job - modification of existing PCB from OSHPARK
« Reply #1 on: December 10, 2020, 07:46:51 pm »
Hello,
Thank you!
Lubos
Do you Have the original pcb soft file :-//
  • Country: cz
« Reply #2 on: December 10, 2020, 07:57:28 pm »
Unfortunately not.
L.
Offline Syntax Error
« Reply #3 on: December 10, 2020, 08:38:17 pm »
Unzipping the files, there's references to: /Users/Richard/Dropbox/EAGLE-7.2.0/projects/7135 Drivers/17mmMLSpecV3 Maybe 'Richard' has a blog? My Google could not find any links.
Otherwise, without the original project files/schematics, importing the layers from gerber (in Kicad to PCB New) gets messy. Plus, at a glance, this pcb might have as many DRC errors as there are pads and tracks? Anyone wanting to do a correct design job for you, will need more than the ready-to-fab files from our friends at OSH Park.
Offline CDN_Torsten
  • Professional electron whisperer
« Reply #4 on: December 11, 2020, 03:07:16 am »
Fully agree with Syntax Error - the design appears to have many DRC issues.
deved - I'd recommend a full re-layout of the board.
Just need a schematic.
  • Country: cz
« Reply #5 on: December 11, 2020, 09:41:39 am »
OK, thank for input - here's the schematics, it's a linear flashlight driver to control the current deliverd to the LED (powered by a single 18650 3,7V battery).
I would need to add 2 more parts (not included in the schema) - SMD diode and proper resistor to indicate "on" state of the flashlight - it should be place on the bottom part.
Lubos
Offline VEGETA
  • Country: jo
  • I am the cult of personality
    • Thundertronics
« Reply #6 on: December 13, 2020, 07:23:42 pm »
If this schematic is all you need, then I can help. Inform me about what you want to modify and form factor... and I will see.
