Author Topic: Toslink splitter mini-project  (Read 1527 times)
Offline dav888Topic starter
  • various artists
« on: December 29, 2020, 03:30:02 pm »
Need help design an active toslink audio splitter (schematic + layout).
• 1 input -> 2 outputs
• usb jack for bus-power
Preferably work in Altium (Kicad also ok)
please DM me
Online Doctorandus_P
Re: Toslink splitter mini-project
« Reply #1 on: January 07, 2021, 05:28:18 pm »
Optical or coax?
Does not matter much, It's just a simple serial datastream and the baudrate is also in the low MHz range.
Coaxial cables are often driven by a transformer, and I've used an RS485 transceiver to drive such a transformer or as input. Just add some common sence to not overload the stuff and adjust signal levels.
