Author Topic: Need PCB designer for OS/OH BLDC motor controller  (Read 2805 times)
Offline SCAR17sTopic starter
« on: November 01, 2015, 05:38:44 am »
Hello, I'm looking for a PCB designer to help with a project I have had going for about 2 years now, I want to create a open hardware pcb for high voltage/current 3 phase BLDC  motor controller. I have lots of the project roughed out (made adapters to use commercial parts ect) But now I'm ready to have a custom pcb made to allow further testing in the field instead of bench testing like I'm limited to now.
Any help is appreciated, and while I don't have tons of money, I'm sure I can compensate the help adequately. I own a small CNC machine shop in Las Vegas, and my shop would be at your disposal if you needed custom metal parts made.
Offline Simon
  • Global Moderator
    • Simon's Electronics
Re: Need PCB designer for OS/OH BLDC motor controller
« Reply #1 on: November 04, 2015, 09:31:37 am »
Sure I have seen this text before
Offline awallin
« Reply #2 on: November 04, 2015, 09:48:04 am »
If it's open source and going for 2 years surely there is a github or similar repo with the schematics and initial pcb design?
This would be interesting for the DIY CNC-mill/lathe and maybe 3D printer crowd also. If you have a credible design and working prototype I'm sure you will find someone willing to work on the PCB.
