Author Topic: Looking for design engineer: 300-400vDC linear regulated power supply, 200ma.  (Read 2216 times)
Offline valvedoctorTopic starter
Hello,
I am looking for an experienced engineer to design a simple linear power supply circuit.
Details are:
This power supply is for the B+ of a tube circuit. It should be adjustable between 300 - 400 vDC, up to a maximum of 200ma.
I would need the transformer secondary winding specs, into a bridge rectifier, followed by a MOSFET or darlington pair into a regulation device such as LM3080. Must be diode protected for accidental shorts. Should be low source impedance and noise must be kept to a minimum. Heatsink requirements is also needed. PCB layout will be done by me.
Please PM me to discuss the project and to send me a quote.
Please have references/resume.
Refer to application notes below for similar circuit ideas.
Regards,
Valvedoctor
http://cds.linear.com/docs/en/datasheet/3080fc.pdf
http://cds.linear.com/docs/en/application-note/an2f.pdf
http://www.ti.com/lit/an/snoa648/snoa648.pdf
Online T3sl4co1l
    • Seven Transistor Labs
Hmm...
Current limiting?
PFC?
Operating temperature range?  Environmental conditions (indoors / low dust, industrial, outdoors, salt spray..)?
Stability (%/month, ppm/month..)?
Lifetime?  (5khr+?)
Target price, in what production qty/yr?
Target NRE/design cost?  Design schedule?
Seven Transistor Labs, LLC
Offline b_force
    • One World Concepts
Send you en PM, are you still looking for people?
