Author Topic: Looking for Li-ion battery experts/consultants  (Read 1502 times)
Offline ForwardVoltageTopic starter
« on: May 16, 2019, 04:22:20 pm »
Hi everyone,
I work at a power supply and battery manufacturer based in the northeast United States. We are looking  to hire an expert consultant to advise us on Li-ion technology, with knowledge of failure modes, electrochemistry, proper system implementation, and really any and all things related to lithium batteries.
If you are interested, please leave your resume and/or any applicable qualifications here, or send me a direct message. If you are comfortable sharing an hourly rate upfront, feel free. If not, we can figure that out. We are dealing primarily with small battery packs of 18650 or 21700 cells used in small to mid sized electronic devices.
Thanks a lot!
Offline zurtle
Re: Looking for Li-ion battery experts/consultants
« Reply #1 on: May 25, 2019, 01:55:02 pm »
Hi there,
I'm a hardware lead at a startup that specializes in lithium ion. Your post was so accurate to what I do that I finally had to create an account.
I've built battery analysers and BMS systems. We've also done a lot of testing by cycling cells upto 2000 cycles and seeing degradation.
As you mentioned, I also primarily work with 18650 cells mostly, although we've also done a lot of prismatic cells.
I will send you a message with more information.
Regards,
Z
« Reply #2 on: May 30, 2019, 02:13:24 pm »
Hi there,
Regards,
Z
Hi Z,
Thanks for responding! I don't see a message from you. If you're still interested please send one my way! Thanks.
