Author Topic: Hardware design  (Read 17441 times)
Offline coppice
Re: Hardware design
« Reply #25 on: May 11, 2017, 11:02:32 am »
Would the be pipelining design or integrated circuit design in this CPU?
I doubt this is a CPU, but the look of it means it was almost certainly a synthesised layout, with very little human involvement. When you say "pipelining" are you referring the the design pipeline, or a pipelined architecture processor? As we don't even know if there are processors in the device its hard to say anything about the architecture. However, almost all modern processors use some form of pipelining, even if its something as simple as overlapping accesses to slow flash memory. If you are referring to the design pipeline, then what aspect of this are you interested in?
