Author Topic: Intel Atom Single Board Computer / Embedded Computer  (Read 13597 times)
Offline mkissin
Re: Intel Atom Single Board Computer / Embedded Computer
« Reply #25 on: January 12, 2016, 07:34:18 am »
I think you should talk to Robert Feranec, he seems to specialize in this sort of embedded designs. I think he has mentioned in some video that he has done Intel Atom boards in the past.
Sent from my HTC One M8s using Tapatalk.
This is an excellent suggestion. Robert has an example cost worked up already: http://www.fedevel.com/welldoneblog/2012/11/how-much-a-custom-motherboard-design-development-costs/
Online nctnico
« Reply #26 on: January 12, 2016, 01:06:34 pm »
I don't think throwing around prices is going to help much. A lot depends on how compact the board must be and how many interfaces need to be routed. A more compact board drives the layout time up exponentially. It also depends on how clever the designer is and how fast/easy to use the PCB package is he/she is using. If you plan ahead during the schematics stage (which means the component placement is done in parallel with the schematics) you can optimise a lot at the schematics stage and reduce the board layout time dramatically.
Offline ChendyTopic starter
« Reply #27 on: March 16, 2016, 10:25:04 am »
Thanks everybody. I understand YMMV but its very useful to me to have prices for example projects. cheers all
