Author Topic: PCB Assembly  (Read 2828 times)
Offline j_omegaTopic starter
PCB Assembly
« on: June 19, 2020, 02:43:56 pm »
I need two separate board designs assembled, 10 of each design.
The PCBs are both 4 layer boards and are all SMT components. I have attached photos of the two boards. One has a QFN48 package. All through-hole components visible in the photo do not need to be populated. See the attached images.
Offline winniethepooh_icu
Re: PCB Assembly
« Reply #1 on: July 26, 2020, 03:53:42 am »
Those look very inexpensive to assemble.  Are you looking for automated assembly?  What state are you in?  You should be able to find an assembly house to do these for very cheap.
Offline SKHILLBILLYSlures
Re: PCB Assembly
« Reply #2 on: June 15, 2022, 01:39:41 am »
if you wanna pm me and we discuss details
but im only interested in a well labelled process. I can't work with what i can't figure out.
There is so much info I'm DroooooooolING all over it
Offline ebastler
Re: PCB Assembly
« Reply #3 on: June 15, 2022, 04:20:51 pm »
The original post is two years old, so those boards have probably been assembled by now. ::)
The following users thanked this post: ANTALIFE
Re: PCB Assembly
« Reply #4 on: July 12, 2022, 10:45:23 pm »
lmao just noticed
F
at least i tried to get an A for effort
