Author Topic: Small PCB update and Schematic design job  (Read 3593 times)
Offline CreateRTopic starter
« on: January 17, 2019, 01:28:43 am »
Hi, Im looking for an electronic engineer to update a PCB and edit some firmware, and to build a simple schematic, source and make sure all components are compatible. This is a short term job. The person would need to speak and write good english. Please be in touch ASAP
Offline maxpayne
Re: Small PCB update and Schematic design job
« Reply #1 on: January 17, 2019, 03:27:49 am »
I can do all the part except the firmware modification.
If you are interested let me know the details.
Offline rhodges
  • Available for embedded projects.
    • My public libraries, code samples, and projects for STM8.
« Reply #2 on: January 17, 2019, 04:25:53 pm »
What is the processor? Do you have the source code, or is this reverse engineering?
Currently developing STM8 and STM32. Past includes 6809, Z80, 8086, PIC, MIPS, PNX1302, and some 8748 and 6805. Check out my public code on github. https://github.com/unfrozen
Offline AndyC_772
« Reply #3 on: January 18, 2019, 02:04:24 pm »
Also, do you have the original PCB design files? What CAD system was used?
Offline rowifi
« Reply #4 on: January 20, 2019, 08:57:40 pm »
Complete design, modification, test, layout and firmware capabilities.  Inc prototype/ preproduction run if needed.
Working with Altium PCB only.
Offline gb88
« Reply #5 on: January 21, 2019, 03:24:17 pm »
Available for the work, i've experience in firmware develop and PCB design.
Offline VAE_TVA
« Reply #6 on: February 20, 2019, 12:56:26 am »
If you still need someone, I can do this job: thomas@vaengineering.be
Both firmware and hardware experience (using Altium19 for hardware).
Offline rahandford
« Reply #7 on: March 01, 2019, 06:22:38 am »
May be able to help if still required please contact me rupert_handford@mr3design.net
