Electronics => PCB/EDA/CAD => KiCad => Topic started by: Sefanoulis7 on March 27, 2022, 02:24:14 pm
When the sensor is in water, the led is on and it works with 12 v dc. I will use 12 sensors in the design of the card, and when the sensor does not see water, the led I used on the card will turn on and the relay and buzzer will work even if any of them are lit. I don’t have much experience for design. Can you help me with this?
https://forum.kicad.info/t/pcb-design-for-water-level-sensor-xkc-y25/34908
this requires you to design a schematic that describes your idea. We have so many commercially available water level detectors and I could advise you buy one of them and have a look at its features, manuals, and operation then try implementing one. Thanks
