Author Topic: [Solved] How to remove the Not Connected "X" on a pin  (Read 6562 times)
Offline kristakisTopic starter
« on: March 11, 2024, 07:39:37 am »
I've marked an unused pin on a µC as Not Connected (with Q) and it put a lovely little "X" there. Now I want to use that pin and I used the Wire tool to connect it to something but the "X" is still there and I can't find a way to remove it.
I'm sure it's simple and obvious but I haven not been able to find anything in the menus or google.
edit: Click on the arms of the X rather than the centre, or use the various selection techniques.
« Last Edit: March 11, 2024, 08:35:46 am by kristakis »
Things I hate:
1. Forum signatures  2. Irony  3. Lists
Online selcuk
  • Country: tr
Re: How to remove the Not Connected "X" on a pin
« Reply #1 on: March 11, 2024, 07:52:48 am »
Did you click on the red X and press delete?
« Reply #2 on: March 11, 2024, 08:11:41 am »
The "X" is blue. I can select the pin and the track but I can't select the "X"
Pin 12 is not connected
Pin 31 is connected as normal
Pin 32 was not connected but I now want it to be connected
(sorry about the image size, I should have zoomed out a bit)
Things I hate:
Online Doctorandus_P
« Reply #3 on: March 11, 2024, 08:24:55 am »
Small things are sometimes a bit hard to select. To fix this, KiCad has implemented a "Long Click". (keep mouse button depressed for around 1s) This long click pops up a context menu which lists all items on that location. So then you can unambiguously select the "No connect" flag and delete it.
Another option is to drag a small box around the no connect flag from left to right. Dragging a box from left to right only selects fully enclosed objects, while dragging a selection box from right to left also includes object that cross the box boundaries.
« Last Edit: March 11, 2024, 08:26:32 am by Doctorandus_P »
The following users thanked this post: kristakis
Online selcuk
  • Country: tr
« Reply #4 on: March 11, 2024, 08:27:32 am »
The color depends on the active theme. I switched to default color theme, placed the blue X with "Q" and was able to delete it. Right click + Delete and Edit Menu + Interactive Delete Tool are also working. KiCAD version is 6.0.5-a6ca702e91~116~ubuntu20.04.1.
« Reply #5 on: March 11, 2024, 08:34:06 am »
Ha! Thank you!
I had been clicking the centre of the X to select it. Clicking on one of the arms did the trick.
Things I hate:
Offline SiliconWizard
Re: [Solved] How to remove the Not Connected "X" on a pin
« Reply #6 on: March 11, 2024, 08:43:35 am »
Yes, selecting it is a bit finicky.
« Reply #7 on: March 11, 2024, 08:48:25 am »
Experiment a bit with those other options I mentioned. It's always good to have (and be familiar) with your options.
