Author Topic: New Kicad Stable Release - Build 3256  (Read 7483 times)
Offline amspire
« on: February 03, 2012, 01:17:29 am »
For a long time, the last stable Kicad release was from July 2011.
There have been new stable releases. The current Windows release is
http://iut-tice.ujf-grenoble.fr/cao/KiCad-2012-01-19-BZR3256-stable-Win_full_with_components_doc_install.exe
There are new tools, and a change to the icons, so if you have Kicad, the new release is worth a look.
Richard
Offline McMonster
    • McMonster's blog
Re: New Kicad Stable Release - Build 3256
« Reply #1 on: February 03, 2012, 01:47:14 am »
Is there a full changelog somewhere?
I think I'll start poking around in the code, there's a lot of space for improvements in this package.
EDIT:
Great idea with the calculator. And the icons are finally from the 21st century. I like this release.
« Last Edit: February 03, 2012, 01:57:20 am by McMonster »
Offline amspire
« Reply #2 on: February 03, 2012, 01:54:41 am »
Have a look at the thread from David: url]https://www.eevblog.com/forum/open-source-kicad-geda/building-kicad-for-windows/[/url]
It is really easy to set up a full KiCad build environment on your PC, and then you can look at the code and compile it. David does give the address of the changelog in this thread.
Richard
Offline Bloch
« Reply #3 on: February 04, 2012, 12:02:49 pm »
New software  :)  Tested on Windows 7
1. Press icon Eeschema
Error file not found....
2. One more time Press icon Eeschema
Now ok.
3. File>open> "demo/electric"
Error elec-unifil.lib fail to load.
Offline amspire
« Reply #4 on: February 04, 2012, 01:02:15 pm »
Now ok.
Some things get configured as you run. Is it OK now?
This lib file is in kicad/share/library, but it needs the first line deleted - it shouldn't be there. The file is dated 2004, and so I guess they tightened up syntax checking and never fixed the error in this old library file.
It should start like this:
EESchema-LIBRARY Version 2.2  Date: 24/11/2004-17:23:54
# A_1KVA
DEF A_1KVA EA 0 10 N Y 1 0 N
Also it is worth pointing out that there are a lot more libraries then you see initially. To see more libraries, you have to go to Preferences->Libraries and click on the first "Add" button.
Since the demos are in the protected Program Files (x86) folder, then anything that needs a write to the disk will fail with a write protect error. If you want to play with the demo's, copy all the files in KiCad/share/examples to a writeable folder on your drive.
Richard
Offline Bloch
« Reply #5 on: February 04, 2012, 01:40:37 pm »
Yes it was only on the first run.
Yes that did remove the error. But I did not see a difference maybe it did load it anyways ?
Thanks I will take a look.
Offline amspire
« Reply #6 on: February 04, 2012, 01:48:25 pm »
The new stable release (3256) is not a new release,  Even though it was released as a stable release in January, it dates back to November 2011.
The  latest daily build is 3396. There is a link in this forum for downloading the latest daily build if you do want to try out the latest, but if you were doing a serious production job, you would stick to the stable release.
