Author Topic: KICAD and dual monitors  (Read 5279 times)
Offline PKTKS
  • Country: br
Re: KICAD and dual monitors
« Reply #50 on: July 07, 2021, 05:02:20 pm »
No my dear...
IT IS A WHOLE DIFFERENT SYSTEM ...
New glibc  new boost  new everything..
It is a whole environment as said
100% safe thing
Running on the same workstation..
SYSTEMD FREE and far from wayland mess
I deal with 8 KiCAD versions... 4 stable wxGtk branches
and **ONE** a single one unstable entry system.
Currently working under GCC10 LLVM12 MESA 20 and boost 1.76
Paul
« Last Edit: July 07, 2021, 05:04:36 pm by PKTKS »
Online Monkeh
« Reply #51 on: July 07, 2021, 05:05:59 pm »
And that's all irrelevant, because the end result is you have another instance of a program operating on a different file. The rest is unnecessary, and it has nothing to do with systemd or Wayland. You could use the exact same binaries running in a chroot or any other form of container to achieve your isolation, and the isolation isn't even needed because they are different files.
Your use-case of running multple different versions of the software is not relevant to the thread. Your hatred of systemd, Wayland, or any other piece of software is not relevant to the thread.
In the current state of KiCAD there are two simple methods to gain a limited second view of a PCB or schematic:
  • Disable autosaves, remove the lock files, and run a second instance (dangerous).
  • Make a second copy of the project and open it with a second instance of the tool (safe enough).
Your method is the second with additional complications fueled by other specific requirements and/or your own desires.
« Last Edit: July 07, 2021, 05:09:34 pm by Monkeh »
Offline PKTKS
  • Country: br
« Reply #52 on: July 07, 2021, 05:09:04 pm »
If that makes you happy... ok
all is irrelevant...
unless that I fetch them from the the same  NAS server  every time
I start to deal with versioning... alas.. they are instantly checked in
and automatic checked out... upon use.
thanks to PERL mods to CVS or SVN
Paul
Offline PKTKS
  • Country: br
« Reply #53 on: July 07, 2021, 05:19:07 pm »
Nah.. none hatred at all..
I made a MINT system to my 6y old nephew play games..
That is exactly made for him..
POTTERIX systems are for that kind of use.
he just loves it..  :popcorn:
Me too watching his grin  ^-^
Paul
Online Zero999
  • 0999
« Reply #54 on: July 08, 2021, 01:19:57 pm »
Paul
Please allow the forum software to wrap your posts, rather than adding needless line breaks, which make your posts difficult to read. If you prefer shorter lines, just resize the window. Please don't inflict it on everyone!
Offline PKTKS
  • Country: br
« Reply #55 on: July 08, 2021, 03:37:09 pm »
You are not the first bugged w that
Sometimes i read forum w cup coffe and cel
. Gez  my fingers can barely fit screen
This size is typical to break.......................
Otherwise i can not use this f* cel
I will try the best
Paul
Offline f4eru
    • Chargehanger
« Reply #56 on: July 11, 2021, 08:00:30 pm »
Guys, please calm down. No need to make a war between graphical lib packages.
There is an easy way to achieve this dual monitor though :
simply use the 3D viewer for the global view, and position it so as to see approx the 2D board.
You can improve the view with transparency of the substrate, and other graphical settings.
The following users thanked this post: nfmax
Online dunkemhigh
« Reply #57 on: July 11, 2021, 08:15:50 pm »
That's a pretty good solution  :-+
It doesn't update as you make changes, but a quick click in that window forces an update, so it's not that difficult to periodically do that. Gosh, if only Altium had a separate 3D window...
