Author Topic: Drag a group of components + wires  (Read 10426 times)
Offline fivefishTopic starter
« on: September 16, 2015, 04:07:59 am »
Can you DRAG a group of components and wires, and have it still be connected to whatever net it's supposed to be connected?
It doesn't seem to work, and instead KiCad just moves the whole group, breaking the connection.
Offline codeboy2k
Re: Drag a group of components + wires
« Reply #1 on: September 18, 2015, 05:34:05 am »
Late to reply here, you might have already discovered this:
1) using the left mouse, draw a box around the group and let go of the mouse key
2) it will start moving the components DISCONNECTED
3a) hit the TAB key on your keyboard, it will keep the wire CONNECTED now
or
3b) right click and get the context menu, choose Drag Block
TAB is the hotkey for Drag Block when in Block Select mode.
It also doesn't make any attempt to keep your dragged wires looking nice :)
The following users thanked this post: quadrant
« Reply #2 on: September 19, 2015, 03:52:28 pm »
or
THANK YOU SO MUCH!!! it works.
I know, same with Eagle. But it's important it keeps the net connection.
