Yep, a mounting hole in Kicad is basically just a footprint with a through hole pad on it. You put it on normal layers as any other component.
Drill file 'power.drl' contains
plated through holes:
T1 0.30mm 0.012" (40 holes)
T9 3.00mm 0.118" (2 holes)
Total plated holes count 236
Not plated through holes are merged with plated holes
unplated through holes:
T10 3.00mm 0.118" (1 hole)
Total unplated holes count 1
BTW, tip - if you add holes by hand (i.e. you don't have them in the schematics/netlist - probably nobody does)
There can be a bit more to it than that. Does the OP want the screw hole to be plated or unplated? Both are legitimate choices in different situations, and you can check what you've specified in the drill report file that KiCad can generate. For example, this board has both plated AND unplated 3mm holes:
Well, I do... But locking the holes is a great idea in any case, to avoid accidentally moving them as you said.
I'll try a few of the ideas later. I got as far as putting a single through hole pad onto the board, also found a few suggestions by google.
I don't need the screw hole to be plated or on the ground plain, but it wouldn't hurt the case is ABS plastic.
(http://i.imgur.com/jvNkBy6.png) (https://imgur.com/jvNkBy6)
I'd rather not have that "REF***" on the silkscreen though :)
click ref** E for properties and untick visible should do it
Ah ha! I was trying to delete it but it won't delete references. Didn't think of hiding it.
Also, a tip to self... put the drill holes in for screws first. Means you stand a chance of laying the board out around them. In this case you can see I can't really use the other screw (top level User Drawing). I did try and move the DC jack around, but it looked like completely redoing the board to accomodate it.
One screw will do!
Thank you for the feedback.
If I move a component the tracks don't follow it. When I move the barrel jack down as far as I can I will still have the screw head screwing down onto the GND pad.
Besides, it's still a little draft as I'm not 100% certain on the footprint of the DC jack. It is assuming I go for a standard SMD one, but I think through hole might be cheaper. So when I make a concrete decision on that I'll try and move it to accomodate the screw.
It did pass DRC checks, but I think the nudge router is set to assume absolute minimum clearance is fine, maybe I should up my minimum clearance a bit until I need it lower.
If it is a regular barrel jack, I would probably go for a normal panel version - the kind that you make a hole in the enclosure wall and then fasten it with a nut and connect to the board using wires.
I'm actually struggling with the DC jack. The random SMD one I picked off RS Components for laying out the board that matched the default KiCad footprint is 10.5mm high, but it's 2.5mm pin diameter. I need 2.1mm.
i have half a dozen DC jacks in the parts bin, but the PCB mount ones are 0.5A and not enough for the purpose. I have 2 panel mount ones and the ebay listing claims 3A... I'm suspicious though.
So... after I submitted the order to PCBWay I discovered the my DC Jack foot print is mirrored.
Make sure you fix the footprint in your library! There's nothing like making the same mistake twice.
On this basis, if I were you, I'd be using the through-hole barrel jacks and electrolytic caps instead of the SMD ones you're using there.
