Electronics => PCB/EDA/CAD => KiCad => Topic started by: Moriambar on January 17, 2021, 01:42:19 pm
Hi.
I never used kicad and I don't know whether this is possible.
I know how to create a new symbol/symbol library and succeeded in doing it; what I would like to do now is to create a component that is made by other components (conceptually the same that is done while creating an IC from discrete parts). This will make my design way easier since I have some repeating blocks.
Can it be done? Can you please help me doing it?
Cheers
This kicad forum discussion from 2018 might be a starting point:
https://forum.kicad.info/t/composite-components-sub-assembly/11868
What would you want to achieve with that? Do you need that for simulation?
It is not 100% clear what you are asking so there might be a language barrier
You use hierarchical sheets, where repeated block point to the same schematic file for the hierarchical sheet.
For a symbol you can have multiple units and copy and paste them to duplicate.
