Author Topic: Help with KiCAD Footprint for Power SOIC-8  (Read 5167 times)
Offline LoveLaika
« on: July 27, 2021, 09:07:41 pm »
I'm using the LM7372 dual op-amp IC as part of my circuit. It comes in a Power-SOIC-8 package with an exposed pad, and I need some help implementing it in KiCAD.
To start off, I uploaded Digikey's library of KiCAD footprints to use as a reference and modified it a bit to match the LM7372 datasheet (shown in image below). I have two questions.
1. The exposed center pad has to be left electrically floating. Since it has vias, I want to add a small copper pour section to form an isolated copper island within my ground plane that is connected to the exposed pad. How do I do that?
2. The original footprint had two square rectangle pads for the exposed pad, with one pad being longer than the other. I deleted the long one as shown in the picture, and I adjusted the center pad so it is the size of what is recommended in the datasheet. For those who have used this type of component before, should I make the exposed pad longer than normal, or should I just keep it the fixed size?
https://www.ti.com/lit/ds/symlink/lm7372.pdf
Offline phil from seattle
Re: Help with KiCAD Footprint for Power SOIC-8
« Reply #1 on: July 28, 2021, 12:41:00 am »
The datasheet shows a different footprint than you describe.  I think I'd follow the datasheet.
There is probably a better way but I would add a pad to the footprint for the exposed pad, add a pin for it in the symbol. In the schematic, connect it to something (so you get a net, maybe create a symbol for that), in the PCB create a filled zone (or zones) for that net and draw it however you like.  Turn off thermal relief for the pad.
Offline LoveLaika
« Reply #2 on: July 28, 2021, 01:19:39 am »
Thanks for replying. If I may, whats different about the footprint? Its mildly different with more via holes and the pads a bit longer, but otherwise, the dimensions are right, and TI's 3D model fits it.
I tried adding a copper pour tied to the exposed pad net on my ground pour,but it didnt isolate from the ground plane.
« Reply #3 on: July 28, 2021, 04:02:34 am »
You described multiple pads.
You need to set the net of the Copper Zone.  I'd guess the one you drew is Gnd.  The screen shot shows a board I made that has GndA - you could use that.  It doesn't connect to Gnd.
Offline LoveLaika
« Reply #4 on: July 28, 2021, 04:09:27 am »
I did do that. My board has a large copper pour tied to GND as the net. I then made another copper pour to fit over that GND pour and tied it to the net as indicated by the exposed pad, but it never showed.
« Reply #5 on: July 28, 2021, 05:54:46 pm »
I don't think you can overlap pours for different nets.  Set a moderately coarse grid and draw an opening in the ground pour.  You might need to split Gnd into 2 pours.
Offline mf_ibfeew
« Reply #6 on: July 28, 2021, 09:29:16 pm »
We don't know your Kicad version.
I'm working actually with v5.99 and overlapping copper pours (filled zones) are possible.
You have to take care to the priority-level, both zones need different values, the inner zone (connecting to your exposed-Pad) with higher priority than the outer GND-zone.
Offline LoveLaika
« Reply #7 on: July 28, 2021, 09:34:48 pm »
I'm running on KiCAD version (5.1.9)-1, release build. Below is the version info:
Application: KiCad
Version: (5.1.9)-1, release build
Libraries:
    wxWidgets 3.0.5
    libcurl/7.71.0 OpenSSL/1.1.1g (Schannel) zlib/1.2.11 brotli/1.0.7 libidn2/2.3.0 libpsl/0.21.0 (+libidn2/2.3.0) libssh2/1.9.0 nghttp2/1.41.0
Platform: Windows 8 (build 9200), 64-bit edition, 64 bit, Little endian, wxMSW
Build Info:
    wxWidgets: 3.0.5 (wchar_t,wx containers,compatible with 2.8)
    Boost: 1.73.0
    OpenCASCADE Community Edition: 6.9.1
    Curl: 7.71.0
    Compiler: GCC 10.2.0 with C++ ABI 1014
« Reply #8 on: July 28, 2021, 09:45:17 pm »
It also works in 5.1.9 (what I'm running).  Good to know.  You will also need to set pad connections to Solid (default is thermal relief).
Offline LoveLaika
« Reply #9 on: July 28, 2021, 10:02:12 pm »
Thanks. I see what the problem is now. It's a combination of zone priorities and the pad's connection to copper zones. For me, the default was 'from parent footprint'. When I changed it 'Solid', it fills in as expected while it's in the designated zone area. Problem solved, but why is setting the pad connection necessary?
