Author Topic: Convert pcb from gEDA to kicad format  (Read 5725 times)
Offline sinkTopic starter
« on: June 14, 2021, 11:03:36 pm »
Hi everyone,
Is there some plugin that will allow me to convert pcb designed in gEDA to kicad pcb project? I was looking for it for some time but I can't find it nowhere.
Thanks
SiNK
Offline Doctorandus_P
Re: Convert pcb from gEDA to kicad format
« Reply #1 on: June 19, 2021, 01:22:24 am »
Create a set of gerber files, then start Kicad and use its Gerbview to export them into a .pcb project.
A lot of information is missing from gerber files, but it's a lot better then nothing.
With this method you get:
* PCB outline & locations of mounting holes.
* All copper tracks.
* Footprint locations (you can place new footprints on the ends of the existing tracks).
* Netlist (This is implicitly created when you put new footprints on the existing tracks).
You have to manually re-create the schematic (And footprint association). I once did this for a test and I made a few mistakes in the re-creation of the schematic, and those were caught because the schematic did not match up with the PCB, and DRC in Pcbnew told me where the errors were.
The following users thanked this post: zzsczz
