Author Topic: kicad on osx  (Read 12758 times)
Offline CodeDogTopic starter
  • cave canem
kicad on osx
« on: March 06, 2012, 06:07:36 am »
Hi all, is anyone running kicad successfully under mac os? If so, can you help me with the required directory structure?
i.e. what directory structures are needed in /Library/Application Support/kicad and /Applications/kicad ?
and which files belong in which subdir?
cheers,
Mark
Offline electrode
Re: kicad on osx
« Reply #1 on: March 06, 2012, 06:18:12 am »
I installed it last year from a guy called brokentoaster, who makes Mac builds. I think I had to get the library files separately.
It was unusable. Dragging and dropping was laggy, to the point where the graphic of the object you were moving became invisible. It may be better now, but it is highly experimental. Use the Linux version under VirtualBox if you are intending to use KiCAD for actual projects.
Offline amspire
Re: kicad on osx
« Reply #2 on: March 06, 2012, 06:30:32 am »
http://interactive-matter.eu/2011/12/installing-kicad-on-mac-os-x/
It is "experimental" so running the windows version in an Windows virtual machine will probably still work much better.
Offline westfw
Re: kicad on osx
« Reply #3 on: March 06, 2012, 09:35:43 am »
When I tried it it seemed unable to recognize mouse movements until the pointer left the window (some sort of event handling bug?)  Unusable. :-(
they should flush native OSX-ness and get it working under X11 on MacOS; that should be pretty much the same as linux, which would be a fine start!
Offline electrode
Re: kicad on osx
« Reply #4 on: March 06, 2012, 09:37:57 am »
You can probably already do that under Wine.
Native OS X is preferable if (when) they get it working.
Offline wkb
Re: kicad on osx
« Reply #5 on: March 06, 2012, 11:10:04 am »
Which would in turn introduce new problems when Mountain Lion hits the street, that is supposedly dropping X11 from the standard OSX distribution.
Offline ivan747
Re: kicad on osx
« Reply #6 on: March 17, 2012, 05:00:44 pm »
You can still install it if some program requires it. When you do a clean OS X install (much more unfrequent than doing so with Windows) X11 is not selected by default. In fact, an installer for X11 used to come in the installation DVD.
Offline wkb
Re: kicad on osx
« Reply #7 on: March 17, 2012, 07:25:00 pm »
Well, yes, I know.  But the way I understood it is that X11 is no longer on the Mountain Lion install DVD.  So you would have to ftp it from the Net.
Offline westfw
Re: kicad on osx
« Reply #8 on: March 17, 2012, 11:12:17 pm »
X11 has a somewhat rocky history in OSX.  Originally, you had to download it.  Then it was included.  Now (Snow Leopard, Lion) there's an X11 on the DVD, but it's not the preferred/maintained version (you should download XQuartz instead.)  I guess in MLion, things have gone full circle...
Offline updatelee
Re: kicad on osx
« Reply #9 on: March 18, 2012, 02:11:56 am »
Ive had better luck with XQuartz as well. been using it for quite some time now.
Offline ivan747
Re: kicad on osx
« Reply #10 on: May 03, 2012, 02:48:04 am »
I hope somebody ports X11 to Mountain Lion. Apple should hide X11 for Mountain Lion deep in a dark corner of their website, for the people who absolutely need it.
On the other hand, if they decide to behave like they use to and totally remove X11, that would force developers to do good quality ports and adding features like panning/zooming gestures. Eagle included these on version 6, and I really like it. I wish all computers and CAD programs had this.
Offline Agent24
Re: kicad on osx
« Reply #11 on: March 29, 2013, 12:44:58 am »
http://www.shaneburrell.com/?p=906
Not sure if it works
To install first install homebrew if you haven't already:
ruby -e "$(curl -fsSL https://raw.github.com/mxcl/homebrew/go)"
Then tap the KICAD homebrew script to build.
brew tap shaneburrell/homebrew-kicad
brew install kicad
To update/upgrade to the latest KICAD as often as you like.
brew update
brew upgrade
Offline Bassman59
  • Yes, I do this for a living
Re: kicad on osx
« Reply #12 on: April 08, 2013, 10:05:23 pm »
cheers,
Mark
