Author Topic: Building KiCAD on Linux Mint 12 (Lisa)  (Read 6961 times)
Offline djsb
« on: December 26, 2011, 05:04:13 pm »
Just thought I'd post an initial link to my experiences of compiling KiCAD on Linux Mint (Lisa) this afternoon.
Please read the comments (when moderated-at the bottom-still not moderated,probably lost) here
http://www.wayneandlayne.com/blog/2010/12/03/how-to-build-kicad-on-ubuntu/
where I detail the error messages and what I did to get round them.
I will collect the information here later on.
Please have a go yourself so that we can iron out any problems together.
Thanks.
David.
P.S If you can't be bothered with compiling code here is a link with nightly builds (for now).
http://kicad.picaxe.cz/
Better to learn how to compile the code for yourself though.
« Last Edit: January 01, 2012, 11:49:10 am by djsb »
Hertfordshire,UK
 University Electronics Technician, London PIC,CCS C,Arduino,Kicad, Altium Designer,LPKF S103,S62 Operator, Electronics instructor.  http://debuggingrules.com/ Give a man a fish and you feed him for a day. Teach a man to fish and you feed him for a lifetime.
Offline djsb
Re: Building KiCAD on Linux Mint 12 (Lisa)
« Reply #1 on: January 01, 2012, 11:45:15 am »
As promised
1/ First download the source code:
sudo apt-get install bzr
bzr checkout lp:kicad kicad.bzr
2/ Next download the build tools
sudo apt-get install build-essential checkinstall cmake doxygen zlib1g-dev
sudo apt-get install debhelper dpatch libx11-dev libglu1-mesa-dev libgl1-mesa-dev messa-common-dev libwxbase2.8-dev libwxgtk2.8-dev libboost-dev fakeroot subversion libboost-serialization-dev
sudo apt-get build-dep kicad
3/ Once the source code has downloaded and all the build tools are installed, go into the new source code directory:
cd kicad.bzr
4/ To keep things cleaner, it's suggested that you create a build directory for the build files:
mkdir kicad-build
cd kicad-build
5/ Kicad uses the CMake tool, so we must run that first:
cmake -DKICAD_TESTING_VERSION=ON ../
6/ CMake generates standard Makefiles, so we proceed in the usual way:
make
If you have multiple processor cores in your computer, you can do some of the work in parallel, by adding -j N to your make line. Replace N with the number of cores in your computer. My computer has two cores, so I used this command to more quickly build Kicad:
make -j 2
7/ Once the build is finished, install the Kicad files:
sudo make install
Now, you can run kicad and check that everything is working.
8/ Once a few days or weeks have passed and you want to get back up to date, start by updating your copy of the Kicad source code:
cd ~/kicad.bzr
bzr update
You probably want to remove all the old build files:
cd build
rm -rf *
Continue as before, for compiling and installing Kicad:
make
sudo make install
We hope this guide was useful and accurate! If you run into any trouble, please leave a comment below and we’ll do our best to help you out.
If you want to also install the Kicad library of parts, you can use these commands:
bzr checkout lp:~kicad-lib-committers/kicad/library kicad-library.bzr
cd kicad-library.bzr/
mkdir build
cd build/
cmake ../
sudo make install
This method has been derived from the wayneandlayne link above. I have added the commands needed to download missing packages and made one or two corrections. All thats needed now is for someone to write a shell script that can be run easily.
Please try this out for yourself.
David.
« Last Edit: January 01, 2012, 11:57:58 am by djsb »
Hertfordshire,UK
Offline amspire
« Reply #2 on: January 01, 2012, 12:24:15 pm »
David,
Thanks. I am right now half way through setting up a Ubuntu Electronic Remix (UER) VMWare virtual machine based on Ubuntu 10.10. There is no ISO for UER, so you have to build up a normal Ubuntu workstation, link it to the UER sources, then install any of the UER packages.
The main reason is I would like to take a look at gEDA and it doesn't run well on Windows - it really needs Linux.
I have got used to using the Daily builds for my Windows KiCad, so I will probably want the same newer versions on Ubuntu. All your notes should work as well on Ubuntu as Mint. I am looking forward to comparing Linux KiCad to Windows KiCad.
Richard
Offline kruegejj
« Reply #3 on: January 04, 2012, 07:14:44 pm »
Thanks for posting this David!
The command sudo apt-get build-dep kicad didn't work for me.  The first error I got was:
E: You must put some 'source' URIs in your sources.list
This was solved by making sure that the Update Manager -> Edit -> Software Sources -> LinuxMint Software -> Source Code box was checked.  After that, the error I got was:
E: Unable to find a source package for kicad.
However, none of this really mattered because the list of apt-get packages you gave above was thorough enough that kicad built without complaint.
