Author Topic: footprinter.xyz - Quick footprints from component datasheets  (Read 1965 times)
Offline fredgreer
Hi all,
I've been hacking away at a little project you might find useful: http://footprinter.xyz/
It's a very basic footprint editor that lets you draw pads on top of the recommended footprints from component datasheets.
There's more information on GitHub at https://github.com/fredgreer/footprinter
Please let me know if it helps you!
The following users thanked this post: ebclr, exe, SparkyFX, schratterulrich
Offline pierreraymondrondelle
Re: footprinter.xyz - Quick footprints from component datasheets
« Reply #1 on: May 19, 2019, 01:02:37 pm »
Please tell me how to use it and what version of Kicad it is compatible with.
Thanks in advance.
Offline Spirit532
  • Country: by
    • My website
« Reply #2 on: May 19, 2019, 09:18:20 pm »
That is really great!
A couple suggestions:
  • Snap alignment of pads to others - not to a grid, just so that they're all straight and of the same size.
  • Very basic edge recognition to snap to lines on the document
« Last Edit: May 19, 2019, 09:19:59 pm by Spirit532 »
Offline ignilux
« Reply #3 on: May 21, 2019, 10:22:27 pm »
Neat! One thing I would suggest would be to have the size of new pads be equal to the size of the most recent pad placed.
Offline Habropoda
« Reply #4 on: May 22, 2019, 12:35:25 am »
There is some sort of copy function shown on the demo but I don't see how it is started.  Is this working for anyone?
Offline Spirit532
  • Country: by
    • My website
« Reply #5 on: May 22, 2019, 12:37:01 am »
Ctrl+C and then Ctrl+V works for me.
Offline Habropoda
« Reply #6 on: May 22, 2019, 12:39:44 am »
That does it.  Thanks!
« Reply #7 on: May 22, 2019, 09:56:22 am »
How do you install / use it ?
There's no executable, so I think that it's a plugin. I'm stuck here !
Regards
Offline Habropoda
« Reply #8 on: May 23, 2019, 04:37:00 am »
It's not a plug in.  It works as a web page in Firefox but would not work in IE.  Try a different browser.
The following users thanked this post: pierreraymondrondelle
Offline ataradov
    • Personal site
« Reply #9 on: May 23, 2019, 05:11:55 am »
Don't those things in the datasheet always say "not to scale" and such?
Alex
The following users thanked this post: exe
« Reply #10 on: May 23, 2019, 10:42:58 am »
Not so obvious to open http://footprinter.xyz/ ! The readme file is very confusing.
Thanks a lot anyway, you put me on the right way.
Regards
Offline free_electron
    • SiliconValleyGarage
« Reply #11 on: May 23, 2019, 11:40:31 am »
yup. exactly my first thought ... also vertical and horizontal may be differently scaled.
i would like to see a 'solidowrks style' interface.
you draw shapes and specify distances / lengths between objects.
Offline Nerull
« Reply #12 on: May 27, 2019, 03:36:42 pm »
Very much this. Every time I have to draw something in any EDA I've tried I find myself really wishing I had a dimension tool.
Offline mark03
« Reply #13 on: May 27, 2019, 04:39:27 pm »
The nice thing about Kicad is that the footprint format is plain text and fairly simple.  With some practice you can have a text editor open in one window, the datasheet in another, and just enter the footprint by hand.  This is much faster than any graphical tool.
Offline thinkfat
    • Matthias' Hackerstübchen
« Reply #14 on: June 03, 2019, 08:30:05 am »
I tried it briefly to create a QFN40 footprint from a datasheet.
  • Precision is not good, to match the pad sizes from the datasheet I still end up entering the actual numbers from the datasheet, I'm not able to match the numbers using the visual interface
  • Positioning of the pads is consequently off
  • Positioning the pads with the mouse is tedious and difficult get the necessary precision
  • Screen captures from the datasheet, which is what I'd mostly do, doesn't give a reference precise enough. All the lines are multiple pixels thick
Footprint attached for reference
« Reply #15 on: June 03, 2019, 03:49:49 pm »
footprints like that are easy to make. it's the crap like this that is a pain in the butt :
Offline thinkfat
« Reply #16 on: June 03, 2019, 08:09:33 pm »
Yeah, I know. If you need a standard footprint there are other, better options, like the footprint wizards in KiCAD
But still, I'd prefer a parametric input instead of a point-n-click interface, which might get me a result quickly but what's it worth if the pads are a couple 10ths of millimeters off because it's not possible to setup the scale or place the pads with enough precision.
« Reply #17 on: June 03, 2019, 09:19:06 pm »
exactly.  Last friday i had to make one for a power ic that had pads with 45 degree and 33 degree angles in them ... QFN device with internal pads ,pads with cutout , pads that widen as the enter the body. And of course datasheet had all measurements .... except the ones i need ( center of pad and pad length and width. They only gave the edge coordinates ... mmaaargghhhhh  so i modeled it in solidworks since there you can easily specify anything to anything and the tool will warp and bend your sketch to your specification. )  load the step file in altium -> create pcb from 3d body model . kaploink. done.
Offline NANDBlog
  • Current job: ATEX certified product design
« Reply #18 on: June 03, 2019, 09:28:45 pm »
And connectors. Especially the ones that come without 3d file to verify, and interlock with an enclosure, with a datasheet full with strange mix of imperial and metric values. Drafted by a person who is a mechanical engineer, never made a footprint in his life and doesn't really speak English.
« Reply #19 on: June 04, 2019, 02:52:50 pm »
yup, those too.. i HATE connectors. to the point that, if a manufacturer can not provide a detailed STEP file i refuse to use their product.
Offline LapTop006
« Reply #20 on: June 07, 2019, 09:45:48 am »
Have you found you're able to trust those STEP files? So far I've always created the part per the numbers and just considered it a bonus if the step file works, let alone is fully detailed (and not obnoxious colours).
