Electronics => PCB/EDA/CAD => KiCad => Topic started by: Dan Moos on August 06, 2017, 07:51:44 pm
I have a 16 bit address bus I want to be on multiple sheets. do I have to send each wire of the bus to each sheet, or is there a way ton just label the bus?
I've haven't used the bus feature yet. Did you see if it would accept a label? If you don't get an answer soon I can ask on the KiCAD forum for you.
Are you looking for a global bus? I don't think there is that feature, but you can route a bus through hierarchical sheets.
https://forum.kicad.info/ is a pretty active forum, you should try it!
