Author Topic: Kicad - GUI is Horrific!  (Read 7344 times)
Offline exe
  • self-educated hobbyist
Re: Kicad - GUI is Horrific!
« Reply #25 on: October 13, 2018, 05:52:41 pm »
I've seen a surprising number of people not being able to do.
Are you talking in general or about kicad? If kicad I can imagine why. But I don't want to put it in dirt, at the end, this is the only opensource tool that is not totally useless.
Offline sokoloff
« Reply #26 on: October 13, 2018, 06:02:38 pm »
if you like to improve the GUI now is the time for it. The current 5.1.0 development is mainly about improving the overall user experience including finding and fixing inconsistencies. You will notice quite a bit of GUI changes compared to KiCad 5.0.0.
I do not share your feeling how KiCad prioritizes work. Working on the GUI is only one of many things, and there are many things to do.
I could live with the GUI if I could just get better automated handoff of the netlist and live updating of the netlist (with an option to disable or perhaps undo the last import) among the various tools. The GUI is a collection of related apps that feels unpolished, but I have to admit that it's functional. (As is the netlist handling to be honest, so I'm even contradicting myself a bit there perhaps...)
It's definitely functional and I can quite reliably get boards out of it. Any limitations with the tool are my own.
Offline james_s
« Reply #27 on: October 13, 2018, 06:47:20 pm »
Mostly Eagle actually, and another older tool the name of which escapes me. I should clarify that I'm talking about hobbyists, not professional engineers.
Offline free_electron
    • SiliconValleyGarage
« Reply #28 on: October 13, 2018, 07:13:33 pm »
hah. you should see the schematics that are made with it ... if you think the Ui is bad ... ( i know , you can draw bad schematics in any package but the default libraries are .. total tripe. it shows that it comes from unix .. 50 years ago.)
Hop on circuitmaker. Free and it works. But.. beware of libraries. many symbols and footprint are wrong because they are cobbled together by newbies. i just did a design in Circuitmaker and had to redo EVERY SINGLE SYMBOL AND FOOTPRINT i used... Some parts are better than others but :
footprints:
- inconsistent layer assignments
- inconsistent line thicknesses
- 3d models on wrong layers, wrong 3d models, blobbed 3d models ( grey boxes) .
- missing courtyard , assembly layers , marker, fiducals
symbols :
- missing pins (especially thermal pads )
- mislabeled pins
- wrong pin numbers
- symbol pins not matching footprint pins.
- random pin lengths, upper case lowercase, special characters like mu and ohm sign that dont render properly
- using dots and commas in part values.
Once i loaded my library : smooth sailing. Got the boards made in china. works like a champ
Offline Bassman59
  • Yes, I do this for a living
« Reply #29 on: October 15, 2018, 10:29:35 pm »
A feature was added awhile to automatically update the board from the schematic without going through the netlist-export/import steps. From either the schematic or the layout, choose "tools => update PCB from schematic." That will automagically generate the netlist from the schematic and import it into the layout using some defaults. If you use the separate steps of generating the netlist and importing it, you get more options.
Importing a netlist to update the layout is a pretty heavy-duty operation. My undo here is simply ensuring that any changes to the layout were committed back to my repository before the netlist import. If it's screwed up or I don't like it, I simply revert the changes.
I know the idea that when the schematic is updated (saved), the layout immediately updates to follow it. But there are many arguments against doing that (hashed out elsewhere) and I think that updating the layout only when you explicitly want to makes the most sense, at least for me.
It was a collection of programs that were put together in a suite, kinda like how many of the PCB layout tools started. Making the user interface the same across the tasks is ongoing development work.
same here.
Offline Bassman59
« Reply #30 on: October 15, 2018, 10:32:15 pm »
It's not about the quirks.
It's about the inconsistencies and KiCad is full of them.
Getting a good consistent GUI for multiple platforms isn't difficult, there are plenty of (free) examples out there that prove it.
Many people have said it before and I repeat it again; it's all about priorities.
Personally I would like to add that it's also about attitude.
With that I mean really listen to the community, people who have been working as a PCB designer for many years.
The developers of KiCad don't really seem to care about it.
Have you filed bug reports and wish list items at the Kicad Launchpad? Do you follow the developers' email listserv so you can see clearly what they are working on and why they've prioritized things the way they do?
The assertion that they don't care is not true.
Offline Lukas
    • carrotIndustries.net
« Reply #31 on: October 15, 2018, 10:57:47 pm »
In fact, I am almost willing to fork the entire project and find a couple of motivated people to work just on the GUI until even my mom can work with it.
I recommend doing that.  Then you will either a) create a much better tool or b) find out writing a much better tool is actually not that easy.
There are projects with similar goals you might want to help out, Horizon LibrePCB. There have been several other people promising to make a "better KiCad" but I don't think they got anywhere.
As the main developer of horizon EDA, I obviously beg to differ. I recently completed the PCB for my master thesis using horizon EDA: https://github.com/carrotIndustries/x-band-tx
Even though some features are still missing, it's perfectly usable for small to medium-sized projects.
Offline b_force
    • One World Concepts
« Reply #32 on: October 15, 2018, 11:19:07 pm »
The biggest flaw in the head of a developer/software programmer.
This is not a bug, this is just fundamental understanding how to build up an intuitive piece of software.
Bit off topic, but I am completely convinced why most open source (not all!) totally fail in the long run because of this flaw.
Don't get me wrong, KiCad has a lot of potential, you can't deny that.
But the interface is made by and for programming geeks, NOT your every day, professional, I need a smooth interface that I can trust PCB user.
Most very good and professional PCB designers don't even know anything about programming or just the basics.
This kind of interface was an excuse 10 years ago maybe, but not anno 2018 anymore.
Yes I (and with me many others) have tried to talk to the developers and get involved.
But with an attitude that "we know it better, and we are not gonna do what all the big companies are doing, meh" you're not gonna make it.
Not to mention the overly sensitivity with every teeny bit of critique that is being given.
Everybody who feels the same and knows how to program, please contact me and I will have a look what we can do.
"If you can't explain it simply (or at all), you don't understand it well enough." A. Einstein
http://www.oneworldconcepts.com/ | http://www.soundprojects.com
Offline Bassman59
« Reply #33 on: October 16, 2018, 12:30:49 am »
Do you really think that the Kicad developers aren't also PCB designers? See, that's why I said you should actually join the developers' listserv to see what is actually going on and see who is actually doing the development. Because you don't know what you're talking about.
You say you've "tried to talk to the developers." Where?
Offline blueskull
  • Country: cn
  • Power Electronics Guy
« Reply #34 on: October 16, 2018, 12:34:20 am »
Since you have access to AD and from my memory you are an AD expert, why bother with CM?
Offline b_force
« Reply #35 on: October 16, 2018, 01:13:36 am »
Don't know what I am talking about?
I just said that I (and other people) contacted them, or shared these stories multiple times.
So or you're not reading properly, or you're implying that I am lying?
Basically their answer is; wait until version 6 and we will see it from there.
« Last Edit: October 16, 2018, 01:18:54 am by b_force »
Offline Monkeh
« Reply #36 on: October 16, 2018, 01:22:56 am »
So basically you're complaining they're not going to throw out their existing development plan and progress to do things your way immediately?
Offline b_force
« Reply #37 on: October 16, 2018, 01:41:23 am »
No????
I am complaining about a bad set of priorities.
Interface should be much higher on the list.
Things like schematic simulators, auto routers and 3D graphics are nice gimmicks, but without a proper user interface it's still not really usable.
Technically KiCad was working adequate from version 4, except for some minor bugs and quirks and other things (that could be done by 3rd party if really needed)
You can even see on their roadmaps were they spend time on.
They should have done this from the beginning.
Nail the user experience first, fix little bugs and things later.
The easy part; there are already a lot of competitors out there, so basically just copy their interface and you already know for sure that at least a big group of people can handle it easily.
(that's basically what they did with DipTrace)
Guess some people just like to reinvent the wheel
« Last Edit: October 16, 2018, 01:48:54 am by b_force »
Offline Dubbie
« Reply #38 on: October 16, 2018, 01:50:21 am »
I agree with b-force.
User experience and user interface need to be numbers 1 and 2 on the list of priorities.
This is what a lot of developers fail to understand. And they forgo huge chunks of potential market share because of it.
Offline james_s
« Reply #39 on: October 16, 2018, 03:48:49 am »
And if they focused on the UI at the expense of everything else, they'd throw out a different section of the market. There are other tools out there with nicer UIs but they are not as flexible or powerful as KiCad. If the UI is that important to you then I suggest using one of the tools that has a more polished UI. The rest of us have managed to work around the UI issues in KiCad, it's just not a big deal.
I've used at least 5 or 6 different EDAs and they all had lousy interfaces, even one that cost thousands of dollars. KiCad is free and it does the job. Frankly I'd be annoyed if the UI changed significantly at this point because I'd have to spend time re-learning how to do things, time that I could instead spend making more boards.
Offline sokoloff
« Reply #40 on: October 16, 2018, 04:34:07 am »
Would it be so bad to fix the fact that you hit "c" to duplicate something in the schematic editor, but Command-D to duplicate something in the PCB layout tool or footprint editor, but it's drag to select and then right mouse to duplicate to duplicate something in the parts library editor (or that you can drag to select and then copy block and when you immediately go to paste the block, you get an error message "Warning: No block to paste")?
If cleaning that up would hurt the usability of the tool for you, then KiCAD project really is stuck between a rock and hard place...
Offline b_force
« Reply #41 on: October 16, 2018, 11:13:55 am »
Most of them have, that is correct.
But it's not a good argument to (therefore) do the seem thing.
At least with most other EDAs the user can change most of the interface to their liking.
And with most of the competitors the user can choice to work mostly with just keyboard shortcuts or only with the mouse or an hybrid..
This is fixed in KiCad and even many icons for certain tasks are completely missing.
Besides, if you read the KiCad 6 roadmap they even admit that the interface is not very logic and inconsistent.
I know it's not a very popular one anymore, but Ultiboard/Multisim is pretty good with their GUI
Easy to learn in just a couple of days and fully customizable.
I find it a bizarre way of working, the other way around.
Technically speaking an interface is also not the most difficult to program.
Like I said before, just basically copy what others did and improve/make it your own from there.
I find it cute to read that the current KiCad users really think they are a significant and representative amount of "the market ".
To be clear, I am not just talking about my personal preference, but what works for many people.
In a sense EDAs always have been very conservative to this compared to 3D CAD software, things like video editors or other sophisticated programs.
Offline Warhawk
    • Personal resume
« Reply #42 on: October 16, 2018, 07:15:49 pm »
Just my two cents. I worked with various EDA tools on hobby as well as on the professional basis. Now I use Altium at work and KiCad at home. I am allowed to use Altium for home projects too but it is not the point.
I want to make my designs available for others and any time and I don't want to shoot myself in the foot again. The thing is, that every single EDA I used for hobby (Diptrace, Eagle, CM) has some limitations. These are typically pins, nets or the PCB size. In the case of CM, it is very inconsistent library quality. I invested time in learning the package, creating libraries and then I hit the limit..
I may loose the access to Altium Designer when I change a job. How do I open my old projects then? Nope, I am not going to pay for Altium. It ain't that good.
Kicad can be an extremely frustrating software package but it is going to be there. I can keep it, I can use it. It does not have limitations perfectly set by the marketing department based on the data from "please help us improve our software" feature.
to the OP: Download Altium or better Orcad demo and create a board there. Then share your feeling about user-friendliness of the tool and also how likely you would pay 10k for it.
« Last Edit: October 16, 2018, 07:22:51 pm by Warhawk »
Offline Warhawk
    • Personal resume
« Reply #43 on: October 16, 2018, 07:18:08 pm »
Lukas, I am not happy seeing another EDA tool because I doubt that you will any bandwidth supporting it after you graduate and find a job but this is impressive. :-+
« Last Edit: October 16, 2018, 07:21:38 pm by Warhawk »
Offline james_s
« Reply #44 on: October 16, 2018, 08:02:05 pm »
Well that wouldn't personally bother me, because I select and shift-select-drag to duplicate everywhere and never even used C or Cmd-D but I agree it would be nice to have consistency there. I've been using it pretty heavily for almost 10 years now so I probably don't even notice many of the things new users complain about.
