Author Topic: Kicad load library  (Read 2150 times)
Offline raphaeldavidf
Kicad load library
« on: February 21, 2015, 08:24:24 am »
Hey guys, first post in the forum  ;)
I'm using kicad for quite some time now and I don't know if this is the default behavior, or I messed something up, but every new project I've to manually reload all my custom libraries and footprints (I keep them with the default ones in /usr/share/kicad/library and /modules) and I find this quite annoying. I searched everywhere in kicad but couldn't find a setting for auto load all the libraries on startup. I'm using kicad Version: (2013-jul-07)-stable.
any help will be very appreciated  :D
Offline Thor-Arne
  • Country: no
  • tinker - tinker, little noob.....
Re: Kicad load library
« Reply #1 on: February 21, 2015, 08:55:52 am »
Locate the kicad.pro file, this is used for the defaults for new projects.
Normaly located in the kicad/share directory.
Open this file and and add all the libraries there.
« Reply #2 on: February 21, 2015, 10:20:37 am »
Thanks a LOT, that solved the problem! ;D
