Well, good luck on your quest!
If all else fails, you could try looking here:
http://kicad-pcb.org/help/tutorials/I would recommend Chris Gammells tutorials, he also runs a course at Contextual Electronics.
I find it quite easy / minimalistic to go between different packages, once you learn how each one calls certain things (terminology) and spend a few hours with the menu's and building test schematics / pcb designs, I know not everyone does,and I think if I was starting out from afresh that Chris' tutorials are some of the better ones.
