Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
PCB/EDA/CAD
KiCad
Rectangular pad drill
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Rectangular pad drill (Read 5235 times)
metRo_
Regular Contributor
Country:
on:
February 24, 2014, 10:30:51 pm »
I'm designing a PCB that will got a RCA connector. How should I design it?
http://anacapa.kycon.com/Pub_Eng_Draw/KLPX-0848A-2-x.pdf
Will I have problems manufacturing it? like at seeedstudio?
Thank you
Logged
tszaboo
Super Contributor
Country:
Current job: ATEX product design
Re: Rectangular pad drill
Reply #1 on:
February 24, 2014, 11:16:18 pm »
It is OK, they have a four dimensional drill, which is rotating in a way that it leaves a square hole in our reality. How do you imagine it?
Make a round hole bigger than your pin. It is that easy.
Logged
metRo_
Regular Contributor
Country:
Reply #2 on:
February 24, 2014, 11:19:12 pm »
But how can I make it rectangular on kicad?
Logged
David_AVD
Super Contributor
Country:
Reply #3 on:
February 24, 2014, 11:31:40 pm »
Do you mean a square hole? In Altium you can make a slotted hole and set the width and length separately.
Logged
jolshefsky
Regular Contributor
Country:
Reply #4 on:
February 25, 2014, 12:58:42 am »
You'd supply a milling layer to the PCB manufacturer along with the other Gerber files.
In KiCAD's module editor, you can make a silkscreen line for your slot then edit the file in a text editor and change the layer number of the line to your milling layer—you'll need to override the function of one of the layers and fiddle with the Gerber files manually. (See
https://en.wikibooks.org/wiki/Kicad/file_formats#Layer_numbering
for layer numbering details ...)
Milling is usually wicked expensive and not worth it for the hobbyist. Better to just make a round hole that's big enough to clear corner-to-corner on the recommended pin. On your example, I'd make both holes around 2.2mm and be done with it.
Logged
May your deeds return to you tenfold.
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
PCB/EDA/CAD
KiCad
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
